Up to 20% off select tools
Jabra Elite 85h Bluetooth Module Replacement
Views: 2.9K
View statistics:
Past 24 Hours:
2
Past 7 Days:
21
Past 30 Days:
82
All Time:
2,862
Comments: 3
1 comment on steps, 2 guide comments.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Tools
  • Spudger
    4.9
Introduction
Go to step 1 ↓
If you are having problems connecting to your Jabra Elite 85H headphones there could be a problem with the Bluetooth module. Follow this guide to correctly disassemble the headsets and repair the module. This guide takes you step by step on how to do it.
    1. Jabra Elite 85h Bluetooth Module Replacement, Bluetooth Module: step 1, image 1 of 3 Jabra Elite 85h Bluetooth Module Replacement, Bluetooth Module: step 1, image 2 of 3 Jabra Elite 85h Bluetooth Module Replacement, Bluetooth Module: step 1, image 3 of 3
      • Remove each ear cushion by hooking your fingers along the inside of the ear cushion and pulling up and away from the ear cup.
      • If the cushion does not fully release, move your hand to the opposite side and pull up inn the same manner.
      Ask FixBot
    2. Jabra Elite 85h Bluetooth Module Replacement: step 2, image 1 of 3 Jabra Elite 85h Bluetooth Module Replacement: step 2, image 2 of 3 Jabra Elite 85h Bluetooth Module Replacement: step 2, image 3 of 3
      • The foam inserts and backing tape are very delicate, take your time when removing them and be careful to not rip or tear the material.
      • Using the small plastic spudger to assist, begin lifting up and removing the foam inserts with attached backing tape.
      Ask FixBot
    3. Jabra Elite 85h Bluetooth Module Replacement: step 3, image 1 of 3 Jabra Elite 85h Bluetooth Module Replacement: step 3, image 2 of 3 Jabra Elite 85h Bluetooth Module Replacement: step 3, image 3 of 3
      • Repeat previous steps on other side.
      Ask FixBot
    4. Jabra Elite 85h Bluetooth Module Replacement: step 4, image 1 of 1
      • Unscrew and remove the four T6 screws holding the speaker in place.
      Ask FixBot
    5. Jabra Elite 85h Bluetooth Module Replacement: step 5, image 1 of 1
      • Tilt the headphones over so that the speaker tilts out of the plastic holder.
      • Repeat for both sides.
      Ask FixBot
    6. Jabra Elite 85h Bluetooth Module Replacement: step 6, image 1 of 2 Jabra Elite 85h Bluetooth Module Replacement: step 6, image 2 of 2
      • Remove the two screws holding the upper and lower circuit boards in place.
      Ask FixBot
    7. Jabra Elite 85h Bluetooth Module Replacement: step 7, image 1 of 2 Jabra Elite 85h Bluetooth Module Replacement: step 7, image 2 of 2
      • Remove the two attached circuit boards from the headphone housing.
      • De-solder Bluetooth Module from control board to replace.
      Ask FixBot
Author
with
Ryan Callaghan
989 Reputation
4 Guides authored
2 Guide Comments
But where could one get this Bluetooth Module? Is it only available for Jabra workers?
sarita sulkakoski - Reply Share
Anyone can tell how I can get parts for this thing - need main module
Janusz Pokorski (Smartthing) - Reply Share
Past 24 Hours: 2
Past 7 Days: 21
Past 30 Days: 82
All Time: 2,862
