Jabra Elite 85h Battery Replacement
  1. Jabra Elite 85h Battery Replacement, Ear Cushion: step 1, image 1 of 3 Jabra Elite 85h Battery Replacement, Ear Cushion: step 1, image 2 of 3 Jabra Elite 85h Battery Replacement, Ear Cushion: step 1, image 3 of 3
    • Remove each ear cushion by hooking your fingers along the inside of the ear cushion and pulling up and away from the ear cup.
    • If the cushion does not fully release, move your hand to the opposite side and pull up inn the same manner.
    Ask FixBot
  2. Jabra Elite 85h Battery Replacement, Speaker: step 2, image 1 of 3 Jabra Elite 85h Battery Replacement, Speaker: step 2, image 2 of 3 Jabra Elite 85h Battery Replacement, Speaker: step 2, image 3 of 3
    • The foam inserts and backing tape are very delicate. Take your time when removing them, and be careful to not rip or tear the material.
    • Using the small plastic spudger to assist, begin lifting up and removing the foam inserts with attached backing tape.
    Ask FixBot
  3. Jabra Elite 85h Battery Replacement: step 3, image 1 of 3 Jabra Elite 85h Battery Replacement: step 3, image 2 of 3 Jabra Elite 85h Battery Replacement: step 3, image 3 of 3
    • Repeat the previous steps for the other side, removing the foam inserts with care.
    Ask FixBot
  4. Jabra Elite 85h Battery Replacement: step 4, image 1 of 1
    • Unscrew and remove the four T6 screws holding the speaker in place.
    Ask FixBot
  5. Jabra Elite 85h Battery Replacement: step 5, image 1 of 1
    • Repeat the previous step for the other side, removing the four T6 screws.
    Ask FixBot
  6. Jabra Elite 85h Battery Replacement: step 6, image 1 of 1
    • Tilt the headphones over so that the speaker tilts out of the plastic holder.
    • Repeat for both sides.
    Ask FixBot
  7. Jabra Elite 85h Battery Replacement, Battery: step 7, image 1 of 1
    • Remove the plastic speaker housing from the left ear of the headphones. This should reveal the battery and motherboard.
    Ask FixBot
  8. Jabra Elite 85h Battery Replacement: step 8, image 1 of 2 Jabra Elite 85h Battery Replacement: step 8, image 2 of 2
    • Using a plastic spudger, release the enclosure from the headband.
    Ask FixBot
  9. Jabra Elite 85h Battery Replacement: step 9, image 1 of 2 Jabra Elite 85h Battery Replacement: step 9, image 2 of 2
    • Unscrew the two screws holding the motherboard in place and remove the motherboard from the enclosure.
    Ask FixBot
  10. Jabra Elite 85h Battery Replacement: step 10, image 1 of 3 Jabra Elite 85h Battery Replacement: step 10, image 2 of 3 Jabra Elite 85h Battery Replacement: step 10, image 3 of 3
    • Flip the motherboard to reveal a 2-pin JST connector. Carefully unplug the connector from the motherboard and use a plastic spudger to remove the battery from the enclosure.
    Ask FixBot
21 other people completed this guide.
Ryan Callaghan
965 Reputation
4 Guides authored
10 Guide Comments
Where do you find a battery to match the connector size?
Karl Schantz - Reply Share
Thanks, I have the Evolve 2 85h, which is similar and this helped me fix it.
I wish to add that my headset refused to charge at all, due to the battery voltage going to low and then the headset did not manage to trickle charge it to a safe charging level. Thus it was dead and Jabra would not repair or replace it claiming the warranty had passed.
By applying 3.8 volts (and limiting it to 300mA) on a test pin connected to the battery + pole for a split second, the charger was tricked into accepting the battery and started charging. Now everything works fine.
Photo of were to apply the voltage. Plus is red. Ground is black.
Some notes -
How it started - I got a battery low warning while listening on a video conference. I attached a USB-C charger cable while wearing the headset. After about 30 minutes the headset just died.
When connecting to a computer, the Jabra App recognized the headset, but said 0% battery. No charging and no Bluetooth communication was possible.
Anders Hedberg - Reply Share
Does it has 2 batteries? One on left and one on right?
Poon - Reply Share
It has just one battery
HardCoreFlowers - Reply Share
I also would like to know how to find a battery that matches the size, or at least gets close enough. Unfortunately just by looking up "3.7v Rechargeable Lithium Polymer Battery" I am finding quite the wide variety of shapes and sizes...
Axe_Metaphor - Reply Share
Past 24 Hours: 8
Past 7 Days: 54
Past 30 Days: 254
All Time: 15,815
