JYX-S55 Speaker Replacement
  1. JYX-S55 Speaker Replacement, Speaker: step 1, image 1 of 2 JYX-S55 Speaker Replacement, Speaker: step 1, image 2 of 2
    • Remove the four screws from the top panel of the device using a 2.5 hex screwdriver.
    • Remove the top panel.
  2. JYX-S55 Speaker Replacement: step 2, image 1 of 1
    • Remove the four screws that keep the light strip in place using a JIS #1 screwdriver.
  3. JYX-S55 Speaker Replacement: step 3, image 1 of 2 JYX-S55 Speaker Replacement: step 3, image 2 of 2
    • Lift out the plastic ring which contains the lights.
    • The lights will be connected with wires. These do not need to be cut or ripped out; simply place the plastic ring off to the side or somewhere out of the way.
  4. JYX-S55 Speaker Replacement: step 4, image 1 of 1
    • Remove the four screws at the corners of the woofer/speaker using a JIS #1 screwdriver.
  5. JYX-S55 Speaker Replacement: step 5, image 1 of 1
    • Pull out the speaker’s woofer.
  6. JYX-S55 Speaker Replacement: step 6, image 1 of 2 JYX-S55 Speaker Replacement: step 6, image 2 of 2
    • Use a pair of wire cutters to separate the speaker from the rest of the device.
2 other people completed this guide.
Alexandra Wehrhahn
169 Reputation
1 Guide authored
Marist, Team 1-5, Chaterdon Spring 2023 Member of Marist, Team 1-5, Chaterdon Spring 2023
MARS-CHATERDON-S23S1G5
3 Members
4 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 58
All Time: 866
