JYX-S55 Motherboard Replacement
    1. JYX-S55 Motherboard Replacement, Motherboard: step 1, image 1 of 1
      Tool used on this step:
      Flathead 3/32" or 2.5 mm Screwdriver
      $5.49
      Buy
      • Remove the six screws around the perimeter of the top panel of the machine using a 2.5 mm flathead screwdriver.
      Ask FixBot
    2. JYX-S55 Motherboard Replacement: step 2, image 1 of 1
      • Grip the top panel with your thumb at the bottom and fingers around the top. Lift the panel until it comes loose.
      Ask FixBot
    3. JYX-S55 Motherboard Replacement: step 3, image 1 of 1
      • Move the top panel backwards and away from you. Let the panel hang down behind the machine, as this will allow you to have access to the components within the machine.
      Ask FixBot
    4. JYX-S55 Motherboard Replacement: step 4, image 1 of 1
      • Remove the screws on the left and right side of the motherboard using a JIS #1 screwdriver.
      • It's important to keep these screws separate from the ones unscrewed from the top of the panel. This is so both sets of screws won't get mixed up.
      Ask FixBot
    5. JYX-S55 Motherboard Replacement: step 5, image 1 of 3 JYX-S55 Motherboard Replacement: step 5, image 2 of 3 JYX-S55 Motherboard Replacement: step 5, image 3 of 3
      • Detach the red and white bricks plugged into the motherboard.
      • This should allow the motherboard to be completely unattached from the device, and ready to handle.
      • Swap the current motherboard with the new replacement part. Then, plug the white brick into the port on the right of the replacement motherboard, and the red brick back in to the center port.
      Ask FixBot
3 other people completed this guide.
Sarah Iceman
502 Reputation
2 Guides authored
Marist, Team 1-5, Chaterdon Spring 2023 Member of Marist, Team 1-5, Chaterdon Spring 2023
MARS-CHATERDON-S23S1G5
3 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 51
All Time: 1,912
