Up to 20% off select tools
JVC XL-333 Power Button Replacement
Views: 1.7K
View statistics:
Past 24 Hours:
4
Past 7 Days:
15
Past 30 Days:
103
All Time:
1,715
Comments: 0
Go to guide comments
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 - 35 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This guide explains how to replace the power button for a JVC XL-333 compact disc player. The steps are fairly simple, and you only need a few basic tools. Most of the steps only require either removing screws or using a spudger (or similar tool) to remove wires that are in the way.
    1. JVC XL-333 Power Button Replacement, The Power Button: step 1, image 1 of 2 JVC XL-333 Power Button Replacement, The Power Button: step 1, image 2 of 2
      • Using your Phillips Head Screwdriver, remove the four screws with the red markup.
      • Then, remove the three orange screws using your screwdriver.
      Ask FixBot
    2. JVC XL-333 Power Button Replacement: step 2, image 1 of 2 JVC XL-333 Power Button Replacement: step 2, image 2 of 2
      • Remove the two Phillips screws on both sides of the CD Player.
      Ask FixBot
    3. JVC XL-333 Power Button Replacement: step 3, image 1 of 3 JVC XL-333 Power Button Replacement: step 3, image 2 of 3 JVC XL-333 Power Button Replacement: step 3, image 3 of 3
      • Remove the top of the CD Player by holding each side of the roof then sliding it away from the front of the CD player.
      Ask FixBot
    4. JVC XL-333 Power Button Replacement: step 4, image 1 of 3 JVC XL-333 Power Button Replacement: step 4, image 2 of 3 JVC XL-333 Power Button Replacement: step 4, image 3 of 3
      • The disk reader is located above the power button.
      • Push out these tabs on both sides of the disk reader.
      Ask FixBot
    5. JVC XL-333 Power Button Replacement: step 5, image 1 of 3 JVC XL-333 Power Button Replacement: step 5, image 2 of 3 JVC XL-333 Power Button Replacement: step 5, image 3 of 3
      • Unscrew the four Phillips copper screws located at the four corners of the disc reader.
      • After the screws are removed, gently pull the disc reader up and out of the CD player.
      Ask FixBot
    6. JVC XL-333 Power Button Replacement: step 6, image 1 of 3 JVC XL-333 Power Button Replacement: step 6, image 2 of 3 JVC XL-333 Power Button Replacement: step 6, image 3 of 3
      Tool used on this step:
      Buy
      • Gently pull up to remove the two bunches of wires with a green connector from the motherboard.
      • Remove the two groups of wires with a white connector by using your spudger or tweezers to pull up on the side of the connector, opposite of the wires. It may require some force
      Ask FixBot
    7. JVC XL-333 Power Button Replacement: step 7, image 1 of 3 JVC XL-333 Power Button Replacement: step 7, image 2 of 3 JVC XL-333 Power Button Replacement: step 7, image 3 of 3
      • These pictures offer other tricks and guidance on how to remove the wire connectors.
      • move your spudger or tweezer in an upward motion to release the wires.
      Ask FixBot
    8. JVC XL-333 Power Button Replacement: step 8, image 1 of 3 JVC XL-333 Power Button Replacement: step 8, image 2 of 3 JVC XL-333 Power Button Replacement: step 8, image 3 of 3
      • Remove the rest of the wires connecting the motherboard to the CD player with your spudger or tweezers.
      • Remove the screw that connects the wire to the motherboard.
      Ask FixBot
    9. JVC XL-333 Power Button Replacement: step 9, image 1 of 3 JVC XL-333 Power Button Replacement: step 9, image 2 of 3 JVC XL-333 Power Button Replacement: step 9, image 3 of 3
      • Find the power button trigger on the left side of the CD Player. It should be gray.
      • Push it a couple times to make sure it works. If not hold it 3/4 of the way and pull with some force.
      • Replace with a new one.
      • Replace the motherboard, reattach the cables and repeat the rest of the previous tasks in reverse.
      Ask FixBot
Author
with
Romenick Casabar
110 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 15
Past 30 Days: 103
All Time: 1,715
