JVC KW-V820BT Front Panel Assembly Replacement
Views: 1.1K
View statistics:
Past 24 Hours:
2
Past 7 Days:
17
Past 30 Days:
63
All Time:
1,145
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
The first step in the service of this device begins with the removal of the front panel assembly. This will allow access to other serviceable components within the device.
Tools
    1. JVC KW-V820BT Front Panel Assembly Replacement, Front Panel Assembly: step 1, image 1 of 3 JVC KW-V820BT Front Panel Assembly Replacement, Front Panel Assembly: step 1, image 2 of 3 JVC KW-V820BT Front Panel Assembly Replacement, Front Panel Assembly: step 1, image 3 of 3
      • Remove the four 1/8-inch black machine screws using a Phillips #00 screwdriver.
      Ask FixBot
    2. JVC KW-V820BT Front Panel Assembly Replacement: step 2, image 1 of 2 JVC KW-V820BT Front Panel Assembly Replacement: step 2, image 2 of 2
      • Remove three steel-finish, pan-head, 1/64 x 3/16" machine screws identified in the photograph, using the Phillips #0 screwdriver.
      Ask FixBot
    3. JVC KW-V820BT Front Panel Assembly Replacement: step 3, image 1 of 3 JVC KW-V820BT Front Panel Assembly Replacement: step 3, image 2 of 3 JVC KW-V820BT Front Panel Assembly Replacement: step 3, image 3 of 3
      • Using your fingers and/or a metal spudger, gently release the plastic locking tabs of the front panel assembly from the steel enclosure while prying the front panel assembly away from the steel enclosure with your fingers.
      Ask FixBot
    4. JVC KW-V820BT Front Panel Assembly Replacement: step 4, image 1 of 1
      • Gently remove the front panel from the steel enclosure.
      Ask FixBot
    5. JVC KW-V820BT Front Panel Assembly Replacement: step 5, image 1 of 3 JVC KW-V820BT Front Panel Assembly Replacement: step 5, image 2 of 3 JVC KW-V820BT Front Panel Assembly Replacement: step 5, image 3 of 3
      • Gently separate the ribbon cable from from ZIF connector on the circuit board using a metal smudger.
      • Be careful not to scratch or damage components or features of the circuit board with the metal spudger
      Ask FixBot
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 63
All Time: 1,145
