JVC GR-D93U Lens Replacement
Views: 1.2K
View statistics:
Past 24 Hours:
6
Past 7 Days:
25
Past 30 Days:
102
All Time:
1,157
Comments: 1
1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 hour
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Markup Mishap
This guide needs better markups. Help out by correcting or making some markup annotations.
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
    1. JVC GR-D93U Lens Replacement, Eye Piece: step 1, image 1 of 2 JVC GR-D93U Lens Replacement, Eye Piece: step 1, image 2 of 2
      • Unscrew two 3mm Phillips #0 screw from the bottom of the camera to remove blue plastic casing.
      Ask FixBot
    2. JVC GR-D93U Lens Replacement: step 2, image 1 of 2 JVC GR-D93U Lens Replacement: step 2, image 2 of 2
      • Unscrew two 3mm Phillips #0 screws. Then remove 6 3mm Philips #0 screws from the bottom of the camera.
      Ask FixBot
    3. JVC GR-D93U Lens Replacement: step 3, image 1 of 1
      • Unscrew 3mm Phillips #0 screws from the batter port under the eye piece.
      Ask FixBot
    4. JVC GR-D93U Lens Replacement: step 4, image 1 of 2 JVC GR-D93U Lens Replacement: step 4, image 2 of 2
      • Now the camera can be split into two pieces. Be careful when removing the two sides and remove the cables connecting the two halves. There are also cables that need to be disconnected from the battery pack section.
      Ask FixBot
    5. JVC GR-D93U Lens Replacement: step 5, image 1 of 3 JVC GR-D93U Lens Replacement: step 5, image 2 of 3 JVC GR-D93U Lens Replacement: step 5, image 3 of 3
      • Unscrew two 3mm Phillips #0 screws from around the eye piece. Then flip the camera over and unscrew 3mm Phillips #0 screw. Then unscrew 3mm Phillips #0 screw from under the eye piece.
      Ask FixBot
    6. JVC GR-D93U Lens Replacement: step 6, image 1 of 2 JVC GR-D93U Lens Replacement: step 6, image 2 of 2
      • Unscrew 3mm Phillips #0 screw and disconnect cable. This will disconnect the eye piece from the camera.
      Ask FixBot
    1. JVC GR-D93U Lens Replacement, Lens: step 7, image 1 of 1
      • Remove the two 3mm screws using the PH0 screwdriver.
      Ask FixBot
    2. JVC GR-D93U Lens Replacement: step 8, image 1 of 1
      • Remove the blue dust cover using the metal spudger. Unscrew the 3mm screw using the PH0 screwdriver.
      Ask FixBot
    3. JVC GR-D93U Lens Replacement: step 9, image 1 of 1
      • Remove the two 5mm screws using the PH0 screw driver. Use the metal spudger to remove plastic casing.
      Ask FixBot
    4. JVC GR-D93U Lens Replacement: step 10, image 1 of 1
      • Remove the 3mm screw using the metal spudger.
      Ask FixBot
    5. JVC GR-D93U Lens Replacement: step 11, image 1 of 1
      • Remove the two logic strips by lifting the plastic clips using the metal spudger.
      Ask FixBot
    6. JVC GR-D93U Lens Replacement: step 12, image 1 of 1
      • Disconnect the power from the lens.
      Ask FixBot
James
146 Reputation
1 Guide authored
1 Guide Comment
Do you fix these yourself? This is too much for me but I love my camera and even though I can watch videos and pictures o the screen I cannot see through the view finder to take pictures. No matter what I do it stays dark. Can you fix it? My email address is sl.green2014@gmail.com. Thank you.
Lee Green - Reply Share
Past 24 Hours: 6
Past 7 Days: 25
Past 30 Days: 102
All Time: 1,157
