Up to 20% off select tools
JVC GR-D93U LCD Screen Replacement
Views: 1.3K
View statistics:
Past 24 Hours:
2
Past 7 Days:
19
Past 30 Days:
101
All Time:
1,275
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Parts
Tools
Introduction
Go to step 1 ↓
The LCD Screen on the GR-D93U is where the viewer can see the video that is being recorded and is where the playback is displayed. It is important to have the screen and can be frustrating if the screen is cracked or won't display content. The process of replacing the screens involves unscrewing a lot of screws so have a place that you will be able to keep the screws.
    1. JVC GR-D93U LCD Screen Replacement, LCD Screen: step 1, image 1 of 3 JVC GR-D93U LCD Screen Replacement, LCD Screen: step 1, image 2 of 3 JVC GR-D93U LCD Screen Replacement, LCD Screen: step 1, image 3 of 3
      • Unscrew 3 mm Phillips #0 screws around the LCD Screen. You will have to turn the screen to get the screws on the bottom of the screen.
      Ask FixBot
    2. JVC GR-D93U LCD Screen Replacement: step 2, image 1 of 1
      • Pry apart the plastic casing around the screen using a flat spudger tool
      Ask FixBot
    3. JVC GR-D93U LCD Screen Replacement: step 3, image 1 of 2 JVC GR-D93U LCD Screen Replacement: step 3, image 2 of 2
      • Carefully remove the wires connected to the screen from the black box. Now you will be able to separate the screen from the camera.
      Ask FixBot
    4. JVC GR-D93U LCD Screen Replacement: step 4, image 1 of 2 JVC GR-D93U LCD Screen Replacement: step 4, image 2 of 2
      • Unscrew the 5 mm Phillips #0 screw that is connecting the screen to the plastic casing.
      Ask FixBot
    5. JVC GR-D93U LCD Screen Replacement: step 5, image 1 of 3 JVC GR-D93U LCD Screen Replacement: step 5, image 2 of 3 JVC GR-D93U LCD Screen Replacement: step 5, image 3 of 3
      • You can now take out the screen to be replaced. Carefully remove cables from the data board.
      Ask FixBot
2 other people completed this guide.
Author
with
Lindsay
321 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 101
All Time: 1,275
