JVC GR-D93U Eye Piece Replacement
  1. JVC GR-D93U Eye Piece Replacement, Eye Piece: step 1, image 1 of 2 JVC GR-D93U Eye Piece Replacement, Eye Piece: step 1, image 2 of 2
    • Unscrew two 3mm Phillips #0 screw from the bottom of the camera to remove blue plastic casing.
    Ask FixBot
  2. JVC GR-D93U Eye Piece Replacement: step 2, image 1 of 2 JVC GR-D93U Eye Piece Replacement: step 2, image 2 of 2
    • Unscrew two 3mm Phillips #0 screws. Then remove 6 3mm Philips #0 screws from the bottom of the camera.
    Ask FixBot
  3. JVC GR-D93U Eye Piece Replacement: step 3, image 1 of 1
    • Unscrew 3mm Phillips #0 screws from the batter port under the eye piece.
    Ask FixBot
  4. JVC GR-D93U Eye Piece Replacement: step 4, image 1 of 2 JVC GR-D93U Eye Piece Replacement: step 4, image 2 of 2
    • Now the camera can be split into two pieces. Be careful when removing the two sides and remove the cables connecting the two halves. There are also cables that need to be disconnected from the battery pack section.
    Ask FixBot
  5. JVC GR-D93U Eye Piece Replacement: step 5, image 1 of 3 JVC GR-D93U Eye Piece Replacement: step 5, image 2 of 3 JVC GR-D93U Eye Piece Replacement: step 5, image 3 of 3
    • Unscrew two 3mm Phillips #0 screws from around the eye piece. Then flip the camera over and unscrew 3mm Phillips #0 screw. Then unscrew 3mm Phillips #0 screw from under the eye piece.
    Ask FixBot
  6. JVC GR-D93U Eye Piece Replacement: step 6, image 1 of 2 JVC GR-D93U Eye Piece Replacement: step 6, image 2 of 2
    • Unscrew 3mm Phillips #0 screw and disconnect cable. This will disconnect the eye piece from the camera.
    Ask FixBot
Lindsay
321 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 31
All Time: 576
