JVC Adixxion GC-XA1BU LCD Screen Replacement
  1. JVC Adixxion GC-XA1BU LCD Screen Replacement, Battery: step 1, image 1 of 1
    • Find the side of the camera with the black switch shown.
    Ask FixBot
  2. JVC Adixxion GC-XA1BU LCD Screen Replacement: step 2, image 1 of 1
    • Push down on the black switch.
    Ask FixBot
  3. JVC Adixxion GC-XA1BU LCD Screen Replacement: step 3, image 1 of 1
    • Slide the battery cover back while pushing down on the black switch.
    Ask FixBot
  4. JVC Adixxion GC-XA1BU LCD Screen Replacement: step 4, image 1 of 2 JVC Adixxion GC-XA1BU LCD Screen Replacement: step 4, image 2 of 2
    • Open the battery compartment and push the blue battery release switch.
    Ask FixBot
  5. JVC Adixxion GC-XA1BU LCD Screen Replacement: step 5, image 1 of 1
    • Remove the battery from the camera.
    Ask FixBot
  6. JVC Adixxion GC-XA1BU LCD Screen Replacement, Battery Cover: step 6, image 1 of 1
    • Remove the two Phillips screws (4mm x 3mm) using the Phillips #00 screwdriver.
    Ask FixBot
  7. JVC Adixxion GC-XA1BU LCD Screen Replacement, LCD Cover: step 7, image 1 of 2 JVC Adixxion GC-XA1BU LCD Screen Replacement, LCD Cover: step 7, image 2 of 2
    • Remove the 8 screws (5mm x 4mm) from the corners of both the front and back of the camera (4 screws on each side) using the T6 Torx screwdriver.
    Ask FixBot
  8. JVC Adixxion GC-XA1BU LCD Screen Replacement: step 8, image 1 of 1
    • Carefully open the camera as shown and gently peel off the black cover tape.
    Ask FixBot
  9. JVC Adixxion GC-XA1BU LCD Screen Replacement: step 9, image 1 of 3 JVC Adixxion GC-XA1BU LCD Screen Replacement: step 9, image 2 of 3 JVC Adixxion GC-XA1BU LCD Screen Replacement: step 9, image 3 of 3
    • Carefully lift up and remove the cable ribbon clip using the tweezers.
    Ask FixBot
  10. JVC Adixxion GC-XA1BU LCD Screen Replacement: step 10, image 1 of 2 JVC Adixxion GC-XA1BU LCD Screen Replacement: step 10, image 2 of 2
    • Carefully grasp and remove the ribbon cable using the tweezers.
    Ask FixBot
  11. JVC Adixxion GC-XA1BU LCD Screen Replacement: step 11, image 1 of 1
    • Turn the camera as shown and carefully remove the glue from the connector.
    Ask FixBot
  12. JVC Adixxion GC-XA1BU LCD Screen Replacement: step 12, image 1 of 2 JVC Adixxion GC-XA1BU LCD Screen Replacement: step 12, image 2 of 2
    • Carefully pull the white clip out of the casing using the tweezers.
    Ask FixBot
  13. JVC Adixxion GC-XA1BU LCD Screen Replacement, Zoom (+/-) Buttons: step 13, image 1 of 2 JVC Adixxion GC-XA1BU LCD Screen Replacement, Zoom (+/-) Buttons: step 13, image 2 of 2
    • Use a Phillips #00 screwdriver to remove the two top screws (4mmx x 3mm). Once the screws are removed, carefully lift off the silver plate using Tweezers.
    Ask FixBot
  14. JVC Adixxion GC-XA1BU LCD Screen Replacement: step 14, image 1 of 1
    • Once you have lifted and removed the silver plate, use a Phillips #00 screwdriver to remove the two bottom screws (4mm x 3mm).
    Ask FixBot
  15. JVC Adixxion GC-XA1BU LCD Screen Replacement: step 15, image 1 of 2 JVC Adixxion GC-XA1BU LCD Screen Replacement: step 15, image 2 of 2
    • Using Tweezers, gently pull the red, black, and white threaded wire to disconnect it, then remove the attached panel as shown.
    Ask FixBot
  16. JVC Adixxion GC-XA1BU LCD Screen Replacement, LCD Screen: step 16, image 1 of 2 JVC Adixxion GC-XA1BU LCD Screen Replacement, LCD Screen: step 16, image 2 of 2
    • Carefully lift up and remove the LCD screen using the tweezers.
    Ask FixBot
  17. JVC Adixxion GC-XA1BU LCD Screen Replacement: step 17, image 1 of 2 JVC Adixxion GC-XA1BU LCD Screen Replacement: step 17, image 2 of 2
    • The screen as shown if removed properly.
    Ask FixBot
Follow these steps in reverse order with the new LCD screen in order to complete the replacement.
Christina Michelle Johnson
1,047 Reputation
8 Guides authored
USF Tampa, Team 1-2, Tanski Winter 2015 Member of USF Tampa, Team 1-2, Tanski Winter 2015
USFT-TANSKI-W15S1G2
4 Members
8 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 36
All Time: 1,020
