JVC Adixxion GC-XA1BU LCD Cover Replacement
  1. JVC Adixxion GC-XA1BU LCD Cover Replacement, Battery: step 1, image 1 of 1
    • Find the side of the camera with the black switch shown.
    Ask FixBot
  2. JVC Adixxion GC-XA1BU LCD Cover Replacement: step 2, image 1 of 1
    • Push down on the black switch.
    Ask FixBot
  3. JVC Adixxion GC-XA1BU LCD Cover Replacement: step 3, image 1 of 1
    • Slide the battery cover back while pushing down on the black switch.
    Ask FixBot
  4. JVC Adixxion GC-XA1BU LCD Cover Replacement: step 4, image 1 of 2 JVC Adixxion GC-XA1BU LCD Cover Replacement: step 4, image 2 of 2
    • Open the battery compartment and push the blue battery release switch.
    Ask FixBot
  5. JVC Adixxion GC-XA1BU LCD Cover Replacement: step 5, image 1 of 1
    • Remove the battery from the camera.
    Ask FixBot
  6. JVC Adixxion GC-XA1BU LCD Cover Replacement, Battery Cover: step 6, image 1 of 1
    • Remove the two Phillips screws (4mm x 3mm) using the Phillips #00 screwdriver.
    Ask FixBot
  7. JVC Adixxion GC-XA1BU LCD Cover Replacement, LCD Cover: step 7, image 1 of 2 JVC Adixxion GC-XA1BU LCD Cover Replacement, LCD Cover: step 7, image 2 of 2
    • Remove the 8 screws (5mm x 4mm) from the corners of both the front and back of the camera (4 screws on each side) using the T6 Torx screwdriver.
    Ask FixBot
  8. JVC Adixxion GC-XA1BU LCD Cover Replacement: step 8, image 1 of 1
    • Carefully open the camera as shown and gently peel off the black cover tape.
    Ask FixBot
  9. JVC Adixxion GC-XA1BU LCD Cover Replacement: step 9, image 1 of 3 JVC Adixxion GC-XA1BU LCD Cover Replacement: step 9, image 2 of 3 JVC Adixxion GC-XA1BU LCD Cover Replacement: step 9, image 3 of 3
    • Carefully lift up and remove the cable ribbon clip using the tweezers.
    Ask FixBot
  10. JVC Adixxion GC-XA1BU LCD Cover Replacement: step 10, image 1 of 2 JVC Adixxion GC-XA1BU LCD Cover Replacement: step 10, image 2 of 2
    • Carefully grasp and remove the ribbon cable using the tweezers.
    Ask FixBot
  11. JVC Adixxion GC-XA1BU LCD Cover Replacement: step 11, image 1 of 1
    • Turn the camera as shown and carefully remove the glue from the connector.
    Ask FixBot
  12. JVC Adixxion GC-XA1BU LCD Cover Replacement: step 12, image 1 of 2 JVC Adixxion GC-XA1BU LCD Cover Replacement: step 12, image 2 of 2
    • Carefully pull the white clip out of the casing using the tweezers.
    Ask FixBot
Christina Michelle Johnson
1,047 Reputation
8 Guides authored
USF Tampa, Team 1-2, Tanski Winter 2015 Member of USF Tampa, Team 1-2, Tanski Winter 2015
USFT-TANSKI-W15S1G2
4 Members
8 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 40
All Time: 707
