JD Razor 2000 Wheelie Bar Replacement
Views: 2K
View statistics:
Past 24 Hours:
8
Past 7 Days:
21
Past 30 Days:
87
All Time:
2,016
Comments: 0
Go to guide comments
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 15 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
The wheelie bar may be deformed or just get in your way constantly. Learn how to remove and/or replace it with this guide.
If you need more assistance, visit our troubleshooting guide here.
Tools
    1. JD Razor 2000 Wheelie Bar Replacement, Unscrewing the Axle Bolt: step 1, image 1 of 2 JD Razor 2000 Wheelie Bar Replacement, Unscrewing the Axle Bolt: step 1, image 2 of 2
      • Facing the wheelie bar as shown, place your left thumb on the bolt located on the left side of the back wheel and place the Allen wrench into the screw on the right side of the back wheel.
      • Using the wrench, slowly unscrew the bolt while applying constant pressure from the left side.
      Ask FixBot
    2. JD Razor 2000 Wheelie Bar Replacement, Removing the Bolt and Bearing: step 2, image 1 of 2 JD Razor 2000 Wheelie Bar Replacement, Removing the Bolt and Bearing: step 2, image 2 of 2
      • Remove the bolt from the right side and the bearing from the left.
      Ask FixBot
    3. JD Razor 2000 Wheelie Bar Replacement, Removing the Wheel: step 3, image 1 of 1
      • Turn the JD Razor 2000 on its side as shown. Slowly remove the back wheel by pulling it out at a perpendicular angle to the scooter base.
      Ask FixBot
    1. JD Razor 2000 Wheelie Bar Replacement, Pulling Out the Wheelie Bar: step 4, image 1 of 1
      • Pull the wheelie bar away from the deck of the scooter.
      Ask FixBot
Shane
384 Reputation
3 Guides authored
Cal Poly, Team 4-46, Amido Fall 2014 Member of Cal Poly, Team 4-46, Amido Fall 2014
CPSU-AMIDO-F14S4G46
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 8
Past 7 Days: 21
Past 30 Days: 87
All Time: 2,016
