JD Razor 2000 Quick-Release Lever Replacement
    1. JD Razor 2000 Quick-Release Lever Replacement, Unlocking the Lever: step 1, image 1 of 2 JD Razor 2000 Quick-Release Lever Replacement, Unlocking the Lever: step 1, image 2 of 2
      • Unlock the quick-release lever by turning the lever from a tightened position.
      Ask FixBot
    2. JD Razor 2000 Quick-Release Lever Replacement, Loosening the Screw: step 2, image 1 of 3 JD Razor 2000 Quick-Release Lever Replacement, Loosening the Screw: step 2, image 2 of 3 JD Razor 2000 Quick-Release Lever Replacement, Loosening the Screw: step 2, image 3 of 3
      • Use a 7/32" Allen Wrench or T25 Screwdriver to loosen the screw shown.
      • Be sure to fasten the opposite side of the screw before unscrewing.
      • Remove the screw and note the order of the parts for reassembly.
      Ask FixBot
    3. JD Razor 2000 Quick-Release Lever Replacement, Removing the Latch: step 3, image 1 of 3 JD Razor 2000 Quick-Release Lever Replacement, Removing the Latch: step 3, image 2 of 3 JD Razor 2000 Quick-Release Lever Replacement, Removing the Latch: step 3, image 3 of 3
      • Turn the quick-release lever over to reveal an 8mm screw.
      • Use the Phillips #2 screw driver to remove the screw.
      • After removing the screw, the circular latch will be detachable.
      Ask FixBot
Shane
384 Reputation
3 Guides authored
Cal Poly, Team 4-46, Amido Fall 2014 Member of Cal Poly, Team 4-46, Amido Fall 2014
CPSU-AMIDO-F14S4G46
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 29
All Time: 2,825
