Up to 20% off select tools
JD Razor 2000 Handle Bar Replacement
Views: 3.4K
View statistics:
Past 24 Hours:
4
Past 7 Days:
20
Past 30 Days:
107
All Time:
3,360
Comments: 4
1 comment on steps, 3 guide comments.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 minutes
Difficulty: Easy
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Tools
Introduction
Go to step 1 ↓
The JD Razor 2000 scooter features two soft-grip handle bars that are each attached to the T-Bar by a fastening button as well as a continuous string with stoppers at each end. This guide will show how to replace a handle bar.
    1. JD Razor 2000 Handle Bar Replacement, Pulling Out the String: step 1, image 1 of 3 JD Razor 2000 Handle Bar Replacement, Pulling Out the String: step 1, image 2 of 3 JD Razor 2000 Handle Bar Replacement, Pulling Out the String: step 1, image 3 of 3
      • Firmly hold the handle bar in place.
      • Grab with one hand the black removable tip of the handle bar and pull it out.
      • Pull out the end of the tied string through the removable tip.
      Ask FixBot
    2. JD Razor 2000 Handle Bar Replacement, Untying the Knot: step 2, image 1 of 2 JD Razor 2000 Handle Bar Replacement, Untying the Knot: step 2, image 2 of 2
      • Untie the knot at the end of the string.
      • If you let go of the string while its in tension, it may recoil far into the other side of the handle bars. To avoid this, bring the end of the string inward towards the hollow section of the handle bar and then carefully let it go.
      Ask FixBot
    3. JD Razor 2000 Handle Bar Replacement, Pulling Out the Handlebar: step 3, image 1 of 2 JD Razor 2000 Handle Bar Replacement, Pulling Out the Handlebar: step 3, image 2 of 2
      • Press down firmly on the golden fastening button located on the handle bar being replaced.
      • While still pressing down on the fastening button, slide the handle bar apart from the T Bar.
      • When re-installing the handlebar (after completion of the guide), you may need a pair of needle-nosed pliers to thread the string back through the handlebar.
      Ask FixBot
2 other people completed this guide.
Author
with
Kevin Church
297 Reputation
2 Guides authored
Cal Poly, Team 4-46, Amido Fall 2014 Member of Cal Poly, Team 4-46, Amido Fall 2014
CPSU-AMIDO-F14S4G46
4 Members
96 Guides authored
3 Guide Comments
Why is the stretchable string for?
dantotford - Reply Share
Where can I buy a wider set of click in handlebars?
Scooterdad - Reply Share
I'm also looking for a JD BUG replacement handlebar, I mean the horizontal parts.
Mon Drianus - Reply Share
Past 24 Hours: 4
Past 7 Days: 20
Past 30 Days: 107
All Time: 3,360
