Up to 20% off select tools
JD Razor 2000 Front Wheel Replacement
Views: 1.8K
View statistics:
Past 24 Hours:
4
Past 7 Days:
19
Past 30 Days:
104
All Time:
1,770
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 - 15 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
The front wheel of the JD Razor 2000 is located directly underneath the handlebar and T-Bar.
    1. JD Razor 2000 Front Wheel Replacement, Removing the 1.75" Axle Bolt: step 1, image 1 of 3 JD Razor 2000 Front Wheel Replacement, Removing the 1.75" Axle Bolt: step 1, image 2 of 3 JD Razor 2000 Front Wheel Replacement, Removing the 1.75" Axle Bolt: step 1, image 3 of 3
      • Orient the scooter so that the front wheel is facing you. Observe the right and left side of the wheel. Remember which is which throughout the guide.
      • Using an Allen wrench, unscrew the axle bolt slowly from the right side while applying a constant pressure with your hand on the left side of the bearing.
      • If the left side of the bolt turns while you unscrew the right side, you will need to use a second Allen wrench to prevent it from moving
      • If the bolt does not move at all, or moves very little, try applying a lubricant on as much of the screw as possible and try again in 5 minutes.
      • Carefully pull apart the bolt and bearing from either side of the wheel.
      Ask FixBot
    2. JD Razor 2000 Front Wheel Replacement, Removing the Wheel: step 2, image 1 of 1
      • Grip the bottom of the wheel and gently slide it out.
      Ask FixBot
Author
with
Kaylan Naicker
255 Reputation
2 Guides authored
Cal Poly, Team 4-46, Amido Fall 2014 Member of Cal Poly, Team 4-46, Amido Fall 2014
CPSU-AMIDO-F14S4G46
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 19
Past 30 Days: 104
All Time: 1,770
