JD Razor 2000 Fastening Button on Handle Bar Replacement
Views: 1.3K
View statistics:
Past 24 Hours:
3
Past 7 Days:
16
Past 30 Days:
83
All Time:
1,297
Comments: 1
1 comment on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
The fastening button on the each of the Razor's handlebars lock the handle securely with the T-Bar. This guide will show you how to remove/replace this fastening button.
Tools
    1. JD Razor 2000 Fastening Button on Handle Bar Replacement, Pulling Out the String: step 1, image 1 of 3 JD Razor 2000 Fastening Button on Handle Bar Replacement, Pulling Out the String: step 1, image 2 of 3 JD Razor 2000 Fastening Button on Handle Bar Replacement, Pulling Out the String: step 1, image 3 of 3
      • Firmly hold the handle bar in place.
      • Grab with one hand the black removable tip of the handle bar and pull it out.
      • Pull out the end of the tied string through the removable tip.
      Ask FixBot
    2. JD Razor 2000 Fastening Button on Handle Bar Replacement, Untying the Knot: step 2, image 1 of 2 JD Razor 2000 Fastening Button on Handle Bar Replacement, Untying the Knot: step 2, image 2 of 2
      • Untie the knot at the end of the string.
      • If you let go of the string while its in tension, it may recoil far into the other side of the handle bars. To avoid this, bring the end of the string inward towards the hollow section of the handle bar and then carefully let it go.
      Ask FixBot
    3. JD Razor 2000 Fastening Button on Handle Bar Replacement, Pulling Out the Handlebar: step 3, image 1 of 2 JD Razor 2000 Fastening Button on Handle Bar Replacement, Pulling Out the Handlebar: step 3, image 2 of 2
      • Press down firmly on the golden fastening button located on the handle bar being replaced.
      • While still pressing down on the fastening button, slide the handle bar apart from the T Bar.
      • When re-installing the handlebar (after completion of the guide), you may need a pair of needle-nosed pliers to thread the string back through the handlebar.
      Ask FixBot
    1. JD Razor 2000 Fastening Button on Handle Bar Replacement, Depressing the Button: step 4, image 1 of 2 JD Razor 2000 Fastening Button on Handle Bar Replacement, Depressing the Button: step 4, image 2 of 2
      • Press strongly down on the golden fastening button located on the loose handle bar.
      Ask FixBot
    2. JD Razor 2000 Fastening Button on Handle Bar Replacement, Grasping the Button: step 5, image 1 of 2 JD Razor 2000 Fastening Button on Handle Bar Replacement, Grasping the Button: step 5, image 2 of 2
      • Tilt the opening of the handle towards you.
      • Reach in carefully with the small needle-nose pliers and firmly grab the golden fastening button.
      Ask FixBot
    3. JD Razor 2000 Fastening Button on Handle Bar Replacement, Pulling out the Button: step 6, image 1 of 2 JD Razor 2000 Fastening Button on Handle Bar Replacement, Pulling out the Button: step 6, image 2 of 2
      • Once grasping the golden fastening button tightly with small needle-nosed pliers, carefully and slowly pull it out of the handle bar.
      • Do not pull out the fastening button rapidly. This may result in the button shooting across the room with great speed.
      Ask FixBot
Kevin Church
297 Reputation
2 Guides authored
Cal Poly, Team 4-46, Amido Fall 2014 Member of Cal Poly, Team 4-46, Amido Fall 2014
CPSU-AMIDO-F14S4G46
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 16
Past 30 Days: 83
All Time: 1,297
