Up to 20% off select tools
JD Razor 2000 Back Wheel Replacement
Views: 1.7K
View statistics:
Past 24 Hours:
2
Past 7 Days:
14
Past 30 Days:
97
All Time:
1,659
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 - 15 minutes
Difficulty: Easy
Parts
Tools
Introduction
Go to step 1 ↓
Every JD Razor 2000 has two wheels, the front wheel which is located directly underneath the handlebar, and the back wheel which is located underneath the wheelie bar. The JD Razor 2000 guide provides instructions for the replacement of the back wheel.
    1. JD Razor 2000 Back Wheel Replacement, Unscrewing the Axle Bolt: step 1, image 1 of 2 JD Razor 2000 Back Wheel Replacement, Unscrewing the Axle Bolt: step 1, image 2 of 2
      • Facing the wheelie bar as shown, place your left thumb on the bolt located on the left side of the back wheel and place the Allen wrench into the screw on the right side of the back wheel.
      • Using the wrench, slowly unscrew the bolt while applying constant pressure from the left side.
      Ask FixBot
    2. JD Razor 2000 Back Wheel Replacement, Removing the Bolt and Bearing: step 2, image 1 of 2 JD Razor 2000 Back Wheel Replacement, Removing the Bolt and Bearing: step 2, image 2 of 2
      • Remove the bolt from the right side and the bearing from the left.
      Ask FixBot
    3. JD Razor 2000 Back Wheel Replacement, Removing the Wheel: step 3, image 1 of 1
      • Turn the JD Razor 2000 on its side as shown. Slowly remove the back wheel by pulling it out at a perpendicular angle to the scooter base.
      Ask FixBot
Author
with
Eric Johnson
311 Reputation
1 Guide authored
Cal Poly, Team 4-46, Amido Fall 2014 Member of Cal Poly, Team 4-46, Amido Fall 2014
CPSU-AMIDO-F14S4G46
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 97
All Time: 1,659
