JBL Xtreme battery replacement
    1. JBL Xtreme battery replacement, Battery: step 1, image 1 of 1
      • 8.4 V battery pack for the JBL Extreme.
      Ask FixBot
    2. JBL Xtreme battery replacement: step 2, image 1 of 1
      • Unscrew the screws and remove the shell.
      Ask FixBot
    3. JBL Xtreme battery replacement: step 3, image 1 of 1
      • Remove the battery pack by unscrewing the 8 screws. Unplug the battery pack. Drill a hole. Seal holes with hot glue for air-tightness.
      Ask FixBot
    4. JBL Xtreme battery replacement: step 4, image 1 of 2 JBL Xtreme battery replacement: step 4, image 2 of 2
      • Solder the positive wires together, and solder the negative wires together. Use a 5.5 x 2.1 hollow DC connector for the power supply. Insulate the cable ends (Heat shrink wrap, electrical tape, etc.)
      Ask FixBot
    5. JBL Xtreme battery replacement: step 5, image 1 of 1
      • Battery, 8.4 Volt. 13200mAh 8.4V Rechargeable Battery Pack Charger for Bicycle Light-XML-T6
      Ask FixBot
    6. JBL Xtreme battery replacement: step 6, image 1 of 1
      • Solarstorm 2S2P 18650 Battery Case.
      • 4xPanasonic NCR18650B 3,7V 3400mAh=14400 mAh
      • + 5V USB ON/OFF Button
      Ask FixBot
4 other people completed this guide.
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Bert
280 Reputation
1 Guide authored
6 Guide Comments
hi
step 2: unscrew the screws …. thats th point, where are the screws. the body looks like glued.
stephan dingsda - Reply Share
Hi.
Don’t ask me, because I have this guide only translated not created. Try to contact the author on de.ifixit.com. I have translated it so, that I tried to don’t change the original text.
Martin
Martin Kubica - Reply Share
I didn’t get it quite clear: is there a original battery replacement or an improvised one? I am interested in replacing mine but I didn’t find the battery.
Chris Fotu - Reply Share
Hi.
See the comment higher.
Martin Kubica
WTF?!? Don’t do this. Buy a replacement battery online, and swap it out. Don’t drill holes, add glue, and try to cram in some battery that isn’t built for it!
fixit4 - Reply Share
Past 24 Hours: 10
Past 7 Days: 38
Past 30 Days: 142
All Time: 31,980
