JBL Xtreme Cover Disassembly
    1. JBL Xtreme Cover Disassembly, Cover: step 1, image 1 of 2 JBL Xtreme Cover Disassembly, Cover: step 1, image 2 of 2
      • Locate the seams next to the 'feet' on the bottom side of the device.
      Ask FixBot
    2. JBL Xtreme Cover Disassembly: step 2, image 1 of 3 JBL Xtreme Cover Disassembly: step 2, image 2 of 3 JBL Xtreme Cover Disassembly: step 2, image 3 of 3
      • Use the metal spudger to gently pry and lift the edge of the seam. The cover is held in place with plastic snaps that will make a popping noise when disengaged. !!Start with the back half, this will expose TWO Screws that need to be removed before lifting the front half.
      Ask FixBot
    3. JBL Xtreme Cover Disassembly: step 3, image 1 of 2 JBL Xtreme Cover Disassembly: step 3, image 2 of 2
      • For the first part of the case: gently pull back the edges of the case rotating along the hinge opposite the opening seam illustrated in the second photo. Plastic snaps hold the cover in place.
      • For the second part of the case: there are 2 screws to be removed at the seam. Once removed, the case will come off completely without forcing.
      Ask FixBot
14 other people completed this guide.
Benny Huynh
2,118 Reputation
4 Guides authored
USF Tampa, Team 1-1, Sullivan Spring 2017 Member of USF Tampa, Team 1-1, Sullivan Spring 2017
USFT-SULLIVAN-S17S1G1
4 Members
60 Guides authored
6 Guide Comments
Can you fix my cover on speaker
c_pg08 - Reply Share
where can I find a new cover for xtreme 2, if possible in black?
vale0501 - Reply Share
If you find a place to buy a cover let me know
abjayaman - Reply Share
you forgot about 2 screws
Enescu Catalin - Reply Share
zapomniałeś o śrubach osoby które o tym mogły nie wiedzieć mogły urwać plastikowy haczyk który utrzymuje przód
megakacper11 - Reply Share
Past 24 Hours: 5
Past 7 Days: 25
Past 30 Days: 154
All Time: 35,727
