JBL Xtreme Charging Port Replacement
    1. JBL Xtreme Charging Port Replacement, Cover: step 1, image 1 of 2 JBL Xtreme Charging Port Replacement, Cover: step 1, image 2 of 2
      • Locate the seams next to the 'feet' on the bottom side of the device.
      Ask FixBot
    2. JBL Xtreme Charging Port Replacement: step 2, image 1 of 3 JBL Xtreme Charging Port Replacement: step 2, image 2 of 3 JBL Xtreme Charging Port Replacement: step 2, image 3 of 3
      • Use the metal spudger to gently pry and lift the edge of the seam. The cover is held in place with plastic snaps that will make a popping noise when disengaged. !!Start with the back half, this will expose TWO Screws that need to be removed before lifting the front half.
      Ask FixBot
    3. JBL Xtreme Charging Port Replacement: step 3, image 1 of 2 JBL Xtreme Charging Port Replacement: step 3, image 2 of 2
      • For the first part of the case: gently pull back the edges of the case rotating along the hinge opposite the opening seam illustrated in the second photo. Plastic snaps hold the cover in place.
      • For the second part of the case: there are 2 screws to be removed at the seam. Once removed, the case will come off completely without forcing.
      Ask FixBot
    1. JBL Xtreme Charging Port Replacement, Bass Radiator: step 4, image 1 of 3 JBL Xtreme Charging Port Replacement, Bass Radiator: step 4, image 2 of 3 JBL Xtreme Charging Port Replacement, Bass Radiator: step 4, image 3 of 3
      • Unscrew the six 9.75mm Phillips head screws holding the bass radiator in place.
      • Three of the five outer screws are indicated in the first image and the sixth inner screw is indicated in the second image.
      Ask FixBot
    2. JBL Xtreme Charging Port Replacement: step 5, image 1 of 3 JBL Xtreme Charging Port Replacement: step 5, image 2 of 3 JBL Xtreme Charging Port Replacement: step 5, image 3 of 3
      • Once the screws have been removed, the bass radiator will easily lift free.
      • Both radiators are identical. Repeat the above steps on the opposite radiator if necessary.
      Ask FixBot
    1. JBL Xtreme Charging Port Replacement, Charging Port: step 6, image 1 of 3 JBL Xtreme Charging Port Replacement, Charging Port: step 6, image 2 of 3 JBL Xtreme Charging Port Replacement, Charging Port: step 6, image 3 of 3
      • Locate and disconnect the the three plugs indicated in these pictures.
      Ask FixBot
    2. JBL Xtreme Charging Port Replacement: step 7, image 1 of 2 JBL Xtreme Charging Port Replacement: step 7, image 2 of 2
      Tool used on this step:
      Buy
      • Unplug the three ports from the previous step.
      • A set of tweezers may be helpful to reach deeper into the device.
      Ask FixBot
    3. JBL Xtreme Charging Port Replacement: step 8, image 1 of 3 JBL Xtreme Charging Port Replacement: step 8, image 2 of 3 JBL Xtreme Charging Port Replacement: step 8, image 3 of 3
      • Locate the three Phillips head screws inside the zipper compartment and unscrew them.
      • Pull the zipper panel free from the device.
      Ask FixBot
    4. JBL Xtreme Charging Port Replacement: step 9, image 1 of 3 JBL Xtreme Charging Port Replacement: step 9, image 2 of 3 JBL Xtreme Charging Port Replacement: step 9, image 3 of 3
      • Under the zipper panel are eight more Phillips head screws. Unscrew them and carefully lift the battery cover.
      • Be careful not to damage the small white ribbon cable which connects the battery cover to the rest of the device.
      Ask FixBot
    5. JBL Xtreme Charging Port Replacement: step 10, image 1 of 2 JBL Xtreme Charging Port Replacement: step 10, image 2 of 2
      • Unscrew the three 11.88mm Phillips head screws highlighted in the picture.
      Ask FixBot
    6. JBL Xtreme Charging Port Replacement: step 11, image 1 of 2 JBL Xtreme Charging Port Replacement: step 11, image 2 of 2
      • Pull the Auxiliary board out.
      • There is foam covering the wires, making it difficult to remove the Auxiliary board. Take your time with this step.
      Ask FixBot
    7. JBL Xtreme Charging Port Replacement: step 12, image 1 of 3 JBL Xtreme Charging Port Replacement: step 12, image 2 of 3 JBL Xtreme Charging Port Replacement: step 12, image 3 of 3
      • The first image highlights the charging port.
      • Locate 6 metal pins highlighted in the second image and use a solder iron to disconnect the pins.
      Ask FixBot
18 other people completed this guide.
Benny Huynh
2,136 Reputation
4 Guides authored
USF Tampa, Team 1-1, Sullivan Spring 2017 Member of USF Tampa, Team 1-1, Sullivan Spring 2017
USFT-SULLIVAN-S17S1G1
4 Members
60 Guides authored
2 Guide Comments
Please I have a JBL XTREME that sparks each time I plug it. What could be the cause
morris_ugwoke - Reply Share
Hi. Can someone advise where a replacement charging port can be sourced? I.e., so I can desolder the existing one and solder a new one in its place. The existing one is badly corroded so the unit won't charge. Thanks Andy
Andy R - Reply Share
Past 24 Hours: 7
Past 7 Days: 62
Past 30 Days: 272
All Time: 28,524
