JBL Xtreme 4 Passive Radiator Replacement
  1. JBL Xtreme 4 Passive Radiator Replacement, Battery: step 1, image 1 of 3 JBL Xtreme 4 Passive Radiator Replacement, Battery: step 1, image 2 of 3 JBL Xtreme 4 Passive Radiator Replacement, Battery: step 1, image 3 of 3
    • Use a T20 Torx screwdriver to remove the two 12.5 mm screws that secure the battery cover.
  2. JBL Xtreme 4 Passive Radiator Replacement: step 2, image 1 of 1
    • Using your fingernail or a spudger, pry open the battery cover.
  3. JBL Xtreme 4 Passive Radiator Replacement: step 3, image 1 of 1
    • Remove the battery by pinching the orange ribbon and gently pulling the battery upwards and out of its slot.
  4. JBL Xtreme 4 Passive Radiator Replacement, Outside Cover: step 4, image 1 of 2 JBL Xtreme 4 Passive Radiator Replacement, Outside Cover: step 4, image 2 of 2
    • Insert the flat end of a spudger into the mesh cover seam beside the battery compartment.
    • Pry on both sides of the battery compartment until the mesh cover releases.
  5. JBL Xtreme 4 Passive Radiator Replacement: step 5, image 1 of 1
    • Use a Phillips screwdriver to remove the two 8.5 mm screws on either side of the battery compartment.
  6. JBL Xtreme 4 Passive Radiator Replacement: step 6, image 1 of 1
    • Lift the speaker out of the cover.
  7. JBL Xtreme 4 Passive Radiator Replacement, Passive Radiator: step 7, image 1 of 3 JBL Xtreme 4 Passive Radiator Replacement, Passive Radiator: step 7, image 2 of 3 JBL Xtreme 4 Passive Radiator Replacement, Passive Radiator: step 7, image 3 of 3
    • Use a Phillips screwdriver to remove the three 8.5 mm screws on the tweeter.
    • Pull the tweeter out from the device.
  8. JBL Xtreme 4 Passive Radiator Replacement: step 8, image 1 of 2 JBL Xtreme 4 Passive Radiator Replacement: step 8, image 2 of 2
    • Pinch the cable connection for the tweeters and pull off.
    • Repeat the previous bullet for the second cable.
  9. JBL Xtreme 4 Passive Radiator Replacement: step 9, image 1 of 3 JBL Xtreme 4 Passive Radiator Replacement: step 9, image 2 of 3 JBL Xtreme 4 Passive Radiator Replacement: step 9, image 3 of 3
    • Use a Phillips the four 12.4 mm screws that secure the passive radiator.
  10. JBL Xtreme 4 Passive Radiator Replacement: step 10, image 1 of 1
    • Remove the passive radiator from the body of the speaker.
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 19
Past 30 Days: 57
All Time: 416
