JBL Xtreme 3 LED Light Replacement
    1. JBL Xtreme 3 LED Light Replacement, Exterior Speaker Shell Cover: step 1, image 1 of 1
      • Find the seam on the speaker and position it upward.
      • Begin by turning the device so that the bottom side with the grooves faces towards you. Using the (5) spudger, carefully pry open the side of the outer shell where the red indicators are to unlatch the outer shell. After they are unlatched, you should be able to open the shell by hand.
      Ask FixBot
    2. JBL Xtreme 3 LED Light Replacement: step 2, image 1 of 1
      • To continue to remove the outer shell, unscrew the two screws (size 1cm) shown in the picture with a size 0 (zero) Phillips screwdriver.
      Ask FixBot
    3. JBL Xtreme 3 LED Light Replacement: step 3, image 1 of 2 JBL Xtreme 3 LED Light Replacement: step 3, image 2 of 2
      • To continue to remove the shell, use a (5) spudger to slowly pop the shell off.
      • There is one nudge in the center below the power and Bluetooth button that should pop off.
      • Once you have unlatched this piece correctly, the shell will remove itself from the speaker. As it is shown in the following figure.
      Ask FixBot
    1. JBL Xtreme 3 LED Light Replacement, LED Light: step 4, image 1 of 1
      • Use a Phillips #0 screwdriver to remove 4 screws from the lighting plate.
      Ask FixBot
    2. JBL Xtreme 3 LED Light Replacement: step 5, image 1 of 1
      • Use a spudger to remove the plate and silicone matting underneath.
      Ask FixBot
    3. JBL Xtreme 3 LED Light Replacement: step 6, image 1 of 1
      • Use a spudger to remove the lightboard.
      • Disconnect the cable. Gently pinch and pull on the white tab until the board and cable disconnect.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 34
All Time: 836
