Introduction
Use this for a step-to-step guide on how to replace either 1 or both hooks on the JBL Xtreme 3.
Please be careful with the small screws as they are easily lost and pose a choking hazard. This is a fairly easy replacement and only takes a couple of minutes.
Find the seam on the speaker and position it upward.
Begin by turning the device so that the bottom side with the grooves faces towards you. Using the (5) spudger, carefully pry open the side of the outer shell where the red indicators are to unlatch the outer shell. After they are unlatched, you should be able to open the shell by hand.
To continue to remove the shell, use a (5) spudger to slowly pop the shell off.
There is one nudge in the center below the power and Bluetooth button that should pop off.
Once you have unlatched this piece correctly, the shell will remove itself from the speaker. As it is shown in the following figure.
Use a #1 Phillip's screwdriver to remove the 2 screws on the hook.
Repeat for the second hook, if needed.
Replace the hook, or both if needed.
