Introduction
Buttons on a JBL speaker can wear out over time due to lifespan and usage. This guide will show you how to remove the button panel on the bottom of the speaker when replacing.
Be CAREFUL when applying pressure to the button system, as to not damage or snap the system.
Find the seam on the speaker and position it upward.
Begin by turning the device so that the bottom side with the grooves faces towards you. Using the (5) spudger, carefully pry open the side of the outer shell where the red indicators are to unlatch the outer shell. After they are unlatched, you should be able to open the shell by hand.
To continue to remove the shell, use a (5) spudger to slowly pop the shell off.
There is one nudge in the center below the power and Bluetooth button that should pop off.
Once you have unlatched this piece correctly, the shell will remove itself from the speaker. As it is shown in the following figure.
