JBL Tune 770NC Battery Replacement
  1. JBL Tune 770NC Battery Replacement, Battery: step 1, image 1 of 3 JBL Tune 770NC Battery Replacement, Battery: step 1, image 2 of 3 JBL Tune 770NC Battery Replacement, Battery: step 1, image 3 of 3
    • Insert a spudger into the seam of the LEFT JBL side plate.
    • Maneuver the tool around side to side in order to loosen the clips inside the plate, working your way around the circular edges.
    • When the plate fully releases, lift it off.
    Ask FixBot
  2. JBL Tune 770NC Battery Replacement: step 2, image 1 of 2 JBL Tune 770NC Battery Replacement: step 2, image 2 of 2
    • Use your fingernails to gently "walk" the battery connector directly out of its socket.
    • The plug may be hot-glued on, but it should disconnect with moderate force.
    Ask FixBot
  3. JBL Tune 770NC Battery Replacement: step 3, image 1 of 3 JBL Tune 770NC Battery Replacement: step 3, image 2 of 3 JBL Tune 770NC Battery Replacement: step 3, image 3 of 3
    • Use a spudger to gently pry the battery out of the chassis.
    • Take care not to bend or puncture the battery.
    Ask FixBot
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
2 Guide Comments
Please share battery side wiring
Sharik Shaikh - Reply Share
Please share battery side wiring colour code
Past 24 Hours: 12
Past 7 Days: 98
Past 30 Days: 458
All Time: 6,793
