JBL Tune 720BT Charging Port Replacement
  1. JBL Tune 720BT Charging Port Replacement, Charging Port: step 1, image 1 of 1
    • Use the Jimmy tool to pry off the back cover of the right ear cup. Apply gentle, steady pressure to release the plastic clips securing the cover.
    • A slight amount of force will be needed to leverage the back off of its clips.
    Ask FixBot
  2. JBL Tune 720BT Charging Port Replacement: step 2, image 1 of 2 JBL Tune 720BT Charging Port Replacement: step 2, image 2 of 2
    • Remove the screws securing the internal board while holding the board in place. Lift off the inside cover to expose the internal components.
    Ask FixBot
  3. JBL Tune 720BT Charging Port Replacement: step 3, image 1 of 2 JBL Tune 720BT Charging Port Replacement: step 3, image 2 of 2
    • Use the Jimmy tool to remove the back cover of the left ear cup to reveal the battery. Disconnect the battery by gently pulling the red, white, and black wires out of their socket.
    • Do not pull on the wires themselves grip the connector to avoid tearing the cables from the board.
    Ask FixBot
  4. JBL Tune 720BT Charging Port Replacement: step 4, image 1 of 2 JBL Tune 720BT Charging Port Replacement: step 4, image 2 of 2
    • Back on the right side, gently flip the board to reveal the charging port.
    • Be careful to ensure you do not over extend the wires.
    • Set the board onto a comfortable position for the next step.
    Ask FixBot
  5. JBL Tune 720BT Charging Port Replacement: step 5, image 1 of 1
    • Use a soldering iron to heat and remove the old port.
    • Solder the new charging port to the soldering points on the board. When you are done soldering, make sure to clean any leftover solder.
    Ask FixBot
To reassemble your device, follow these steps in reverse order. Make sure all connectors are secure and that no cables are pinched before snapping the covers back into place.
brug
131 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 28
Past 30 Days: 140
All Time: 1,328
