JBL Tune 710BT Battery Replacement
Views: 3.4K
View statistics:
Past 24 Hours:
6
Past 7 Days:
38
Past 30 Days:
188
All Time:
3,378
Comments: 4
1 comment on steps, 3 guide comments.
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Needs More Images
A few more images would make this guide's procedures crystal clear.
Introduction
Go to step 1 ↓
This guide provides detailed instructions on how to replace the battery in your JBL Tune 710BT headphones. Whether your battery has reached the end of its lifespan or you're experiencing reduced performance, this guide will help you through the process of battery replacement, requiring careful disassembly and reassembly of the headphones.
Regarding the time required for repair or replacement, it typically ranges from 30 minutes to an hour, depending on the skill level of the individual and the complexity of the issue. This process involves delicately navigating the internal components of the headphones to access the battery compartment, followed by meticulous attention to detail during the repair or replacement procedure.
Tools
    1. JBL Tune 710BT Battery Replacement, Battery: step 1, image 1 of 1
      • Ensure your JBL Tune 710BT headphones are fully powered off.
      • Gather your tools and a clean, well-lit workspace.
      Ask FixBot
    2. JBL Tune 710BT Battery Replacement: step 2, image 1 of 1
      • Use the plastic opening tool to gently pry open the earcup covering the battery. This is usually found under the cushioned part of the earcup.
      • Be gentle to avoid damaging the earcup or the internal components.
      Ask FixBot
    3. JBL Tune 710BT Battery Replacement: step 3, image 1 of 1
      • Once disconnected, gently remove the old battery from the compartment.
      • If the battery is adhered in place, gently pry it loose, taking care not to damage the compartment or nearby components.
      Ask FixBot
    4. JBL Tune 710BT Battery Replacement: step 4, image 1 of 1
      • Place the new battery in the compartment, ensuring it sits flat and secure.
      • Reconnect the battery connector, ensuring it is snug and properly aligned.
      Ask FixBot
    5. JBL Tune 710BT Battery Replacement: step 5, image 1 of 1
      • Carefully align the earcup cover and press it back into place. Ensure all clips and seams are securely fastened and aligned.
      • Test the headphones to ensure the new battery is functioning correctly.
      Ask FixBot
After following these steps, your JBL Tune 710BT headphones should have a new lease on life with a fresh battery. Proper reassembly ensures the longevity and optimal performance of your headphones.
Additional Tips:
  • Handle all electronic components with care to avoid static discharge or damage.
  • Ensure the replacement battery is the correct model and specification for the JBL Tune 710BT headphones.
  • Dispose of the old battery properly, following local regulations for battery recycling.
By completing this guide, users can extend the lifespan of their JBL Tune 710BT headphones and enjoy uninterrupted listening experiences.
4 other people completed this guide.
Ethan Caleb Francis
222 Reputation
1 Guide authored
3 Guide Comments
Well done - I need new bluetooth hdphones, and ease of battery replacement is key.
QUESTION: do you know the replacement battery specs???
FWIW - Reply Share
Nowhere to find a replacement battery !
Frank Degueret - Reply Share
Hello, I encountered a problem finding the right battery for the jbl 710 tune headphones. They are sold everywhere with 3 wires, but as far as I know, 4 wires are required. Can you tell me where I can buy the right battery?
Алдияр Раимкулов - Reply Share
Past 24 Hours: 6
Past 7 Days: 38
Past 30 Days: 188
All Time: 3,378
