JBL Tune 510BT Power Button Replacement
    1. JBL Tune 510BT Power Button Replacement, Faceplate: step 1, image 1 of 2 JBL Tune 510BT Power Button Replacement, Faceplate: step 1, image 2 of 2
      • Firmly grasp the earmuff and pull away from the center until the lip of the earmuff is disengaged.
      • Pull the earmuff towards the center of the headphones until it is free.
      Ask FixBot
    2. JBL Tune 510BT Power Button Replacement: step 2, image 1 of 2 JBL Tune 510BT Power Button Replacement: step 2, image 2 of 2
      • Remove the three 3 mm screws using a JIS #00 screwdriver.
      Ask FixBot
    3. JBL Tune 510BT Power Button Replacement: step 3, image 1 of 1
      • Carefully remove the faceplate by lifting it firmly.
      • Avoid rough movements, as there is a single thin wire connecting the faceplate to the internals.
      • If the repair is for the right-side driver, be mindful of the charging port, as the faceplate has a slot there for it. Lift the opposite end and back the port out.
      • To completely detach the faceplate, desolder the wires from the connections on the motherboard.
      Ask FixBot
    1. JBL Tune 510BT Power Button Replacement, Power Button: step 4, image 1 of 2 JBL Tune 510BT Power Button Replacement, Power Button: step 4, image 2 of 2
      • Remove the 1 mm screw using a JIS #00 screwdriver.
      • Using your finger or a Jimmy, gently pry the circuit board from the casing, being careful to not pull too hard to dislodge the connected wires.
      Ask FixBot
    2. JBL Tune 510BT Power Button Replacement: step 5, image 1 of 2 JBL Tune 510BT Power Button Replacement: step 5, image 2 of 2
      • Gently push the damaged power button from the outside towards the inner part of the headphone casing until it dislodges.
      • Replace it with the new button by connecting the tabs at the top and swinging the button into place.
      Ask FixBot
3 other people completed this guide.
Andy Rich
334 Reputation
2 Guides authored
2 Guide Comments
Ref. Power button ?
Marcel De Taey - Reply Share
Part number to replace the powder button?? 510BT
Chris - Reply Share
Past 24 Hours: 8
Past 7 Days: 75
Past 30 Days: 314
All Time: 7,645
