JBL Spyro/Spot Partial Disassembly
    1. JBL Spyro/Spot Partial Disassembly, Locate the risers: step 1, image 1 of 1
      • Locate the 3 risers the hold the base plate in place
      Ask FixBot
    2. JBL Spyro/Spot Partial Disassembly, Pry the plugs from the risers: step 2, image 1 of 1
      • Insert a strong spudger or flathead near the riser and gently pry until the plug starts to come out. Work your way around to loosening each one.
      Ask FixBot
    3. JBL Spyro/Spot Partial Disassembly, Remove the base plate: step 3, image 1 of 1
      • With all three loosened remove the base!
      • Note the not equilateral placement of the risers when replacing the base.
      Ask FixBot
19 other people completed this guide.
Ryan McLeod
654 Reputation
2 Guides authored
13 Guide Comments
Thanks, so nice tip. I'll see if I can find a similar speaker, big hug.
durval - Reply Share
No problem!!
Ryan McLeod - Reply Share
My speaker is broken like on the image above and it sounds horrible. Do you know where to buy similar speaker in order to replice it?
pszopa - Reply Share
Does anybody know, if I can get a replacement speaker for the subwoofer of the JBL 2.1. system? Thanks!
Lars - Reply Share
I was unable to find a replacement for the Atlas subwoofer it uses and ended up "recycling" the whole thing :( I've since replaced it with the the Klipsch ProMedia 2.1s and love them.
Past 24 Hours: 4
Past 7 Days: 24
Past 30 Days: 100
All Time: 15,843
