JBL Pulse Speakers Replacement
  1. JBL Pulse Speakers Replacement, Button Board: step 1, image 1 of 1
    • Use a plastic opening tool to pry around the edges of the circular rubber panel.
    Ask FixBot
  2. JBL Pulse Speakers Replacement: step 2, image 1 of 1
    • Once the edges are loose, pull off the rubber button panel completely.
    • New adhesive will have to be applied when reassembling.
    Ask FixBot
  3. JBL Pulse Speakers Replacement: step 3, image 1 of 1
    • Use your plastic opening tool to pry the button board loose by lifting the edges.
    Ask FixBot
  4. JBL Pulse Speakers Replacement: step 4, image 1 of 1
    • Lift the button board, exposing the attached cable.
    Ask FixBot
  5. JBL Pulse Speakers Replacement: step 5, image 1 of 1
    • Pull black piece on top of socket away from board to loosen, then detach the cable.
    Ask FixBot
  6. JBL Pulse Speakers Replacement, Outer Casing: step 6, image 1 of 3 JBL Pulse Speakers Replacement, Outer Casing: step 6, image 2 of 3 JBL Pulse Speakers Replacement, Outer Casing: step 6, image 3 of 3
    • Take out the four 9mm black PH0 screws from the top and bottom of the device.
    • Pull off cap by hand.
    • The outer casing can now be removed.
    Ask FixBot
  7. JBL Pulse Speakers Replacement, JBL Pulse LED Lights Disassembly: step 7, image 1 of 2 JBL Pulse Speakers Replacement, JBL Pulse LED Lights Disassembly: step 7, image 2 of 2
    • Remove the tape around the cables on the top of the device.
    • Remove the cables by lifting up on the black bracket and then pulling the cable out.
    Ask FixBot
  8. JBL Pulse Speakers Replacement, JBL Pulse Disassembly: step 8, image 1 of 1
    • Remove two black 9mm PH0 screws from outside of inner casing on each side.
    Ask FixBot
  9. JBL Pulse Speakers Replacement: step 9, image 1 of 3 JBL Pulse Speakers Replacement: step 9, image 2 of 3 JBL Pulse Speakers Replacement: step 9, image 3 of 3
    • Use your metal spudger to unhook the bracket holding the case together.
    • Pull apart the casing with your hands.
    Ask FixBot
  10. JBL Pulse Speakers Replacement: step 10, image 1 of 2 JBL Pulse Speakers Replacement: step 10, image 2 of 2
    • Remove cables by pulling firmly.
    Ask FixBot
  11. JBL Pulse Speakers Replacement, Speakers: step 11, image 1 of 2 JBL Pulse Speakers Replacement, Speakers: step 11, image 2 of 2
    • Remove four black PH0 9mm screws.
    • The only thing still attaching the speakers is the wires to the soldering points. Cut wires at soldering points.
    • New speakers will have to be re-soldered to these wires.
    Ask FixBot
7 other people completed this guide.
Maxwell Busenbarrick
1,401 Reputation
7 Guides authored
USF Tampa, Team 18-6, Blackwell Fall 2016 Member of USF Tampa, Team 18-6, Blackwell Fall 2016
USFT-BLACKWELL-F16S18G6
3 Members
13 Guides authored
9 Guide Comments
Hi,
Thanks for your guide. Where did you obtain replacement speakers?
heaton.steven - Reply Share
Hi. Even I would like to know a good replacement/ substitute speaker for this. Thanks
Vishakh A V - Reply Share
Hi.
Even I would like to know where I can find a replacement or an alternate speaker..
what is the speaker specification that I can buy for replacement?
rbalagr - Reply Share
Could you please share any links to buy these spare speakers ..Thanks in advance ☺️
deepak gupta - Reply Share
Past 24 Hours: 4
Past 7 Days: 11
Past 30 Days: 60
All Time: 8,408
