Up to 20% off select tools
JBL Pulse Outer Casing Replacement
Views: 3.3K
View statistics:
Past 24 Hours:
5
Past 7 Days:
20
Past 30 Days:
106
All Time:
3,286
Comments: 4
4 comments on steps.
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 20 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This guide is for replacing the outer casing of the JBL Pulse for when some kind of damage has occurred to the outside of the device.
    1. JBL Pulse Outer Casing Replacement, Button Board: step 1, image 1 of 1
      • Use a plastic opening tool to pry around the edges of the circular rubber panel.
      Ask FixBot
    2. JBL Pulse Outer Casing Replacement: step 2, image 1 of 1
      • Once the edges are loose, pull off the rubber button panel completely.
      • New adhesive will have to be applied when reassembling.
      Ask FixBot
    3. JBL Pulse Outer Casing Replacement: step 3, image 1 of 1
      • Use your plastic opening tool to pry the button board loose by lifting the edges.
      Ask FixBot
    4. JBL Pulse Outer Casing Replacement: step 4, image 1 of 1
      • Lift the button board, exposing the attached cable.
      Ask FixBot
    5. JBL Pulse Outer Casing Replacement: step 5, image 1 of 1
      • Pull black piece on top of socket away from board to loosen, then detach the cable.
      Ask FixBot
    1. JBL Pulse Outer Casing Replacement, Outer Casing: step 6, image 1 of 3 JBL Pulse Outer Casing Replacement, Outer Casing: step 6, image 2 of 3 JBL Pulse Outer Casing Replacement, Outer Casing: step 6, image 3 of 3
      • Take out the four 9mm black PH0 screws from the top and bottom of the device.
      • Pull off cap by hand.
      • The outer casing can now be removed.
      Ask FixBot
3 other people completed this guide.
Author
with
Maxwell Busenbarrick
1,401 Reputation
7 Guides authored
USF Tampa, Team 18-6, Blackwell Fall 2016 Member of USF Tampa, Team 18-6, Blackwell Fall 2016
USFT-BLACKWELL-F16S18G6
3 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 20
Past 30 Days: 106
All Time: 3,286
