Up to 20% off select tools
JBL Pulse LED Light Replacement
Views: 4.2K
View statistics:
Past 24 Hours:
3
Past 7 Days:
21
Past 30 Days:
100
All Time:
4,153
Comments: 5
4 comments on steps, 1 guide comment.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 25 minutes
Difficulty: Moderate
Parts
Tools
Introduction
Go to step 1 ↓
When the lights are displaying improperly, usually replacing the LED lights will fix the problem.
    1. JBL Pulse LED Light Replacement, Button Board: step 1, image 1 of 1
      • Use a plastic opening tool to pry around the edges of the circular rubber panel.
      Ask FixBot
    2. JBL Pulse LED Light Replacement: step 2, image 1 of 1
      • Once the edges are loose, pull off the rubber button panel completely.
      • New adhesive will have to be applied when reassembling.
      Ask FixBot
    3. JBL Pulse LED Light Replacement: step 3, image 1 of 1
      • Use your plastic opening tool to pry the button board loose by lifting the edges.
      Ask FixBot
    4. JBL Pulse LED Light Replacement: step 4, image 1 of 1
      • Lift the button board, exposing the attached cable.
      Ask FixBot
    5. JBL Pulse LED Light Replacement: step 5, image 1 of 1
      • Pull black piece on top of socket away from board to loosen, then detach the cable.
      Ask FixBot
    1. JBL Pulse LED Light Replacement, Outer Casing: step 6, image 1 of 3 JBL Pulse LED Light Replacement, Outer Casing: step 6, image 2 of 3 JBL Pulse LED Light Replacement, Outer Casing: step 6, image 3 of 3
      • Take out the four 9mm black PH0 screws from the top and bottom of the device.
      • Pull off cap by hand.
      • The outer casing can now be removed.
      Ask FixBot
    1. JBL Pulse LED Light Replacement, JBL Pulse LED Lights Disassembly: step 7, image 1 of 2 JBL Pulse LED Light Replacement, JBL Pulse LED Lights Disassembly: step 7, image 2 of 2
      • Remove the tape around the cables on the top of the device.
      • Remove the cables by lifting up on the black bracket and then pulling the cable out.
      Ask FixBot
    1. JBL Pulse LED Light Replacement, LED Light: step 8, image 1 of 1
      • Pry off LED light panel using a metal spudger.
      Ask FixBot
2 other people completed this guide.
Author
with
Maxwell Busenbarrick
1,401 Reputation
7 Guides authored
USF Tampa, Team 18-6, Blackwell Fall 2016 Member of USF Tampa, Team 18-6, Blackwell Fall 2016
USFT-BLACKWELL-F16S18G6
3 Members
84 Guides authored
1 Guide Comment
Were do I buy a Replacement led strip?
Jalen6988 - Reply Share
Past 24 Hours: 3
Past 7 Days: 21
Past 30 Days: 100
All Time: 4,153
