Introduction
If your JBL Pulse 4 speaker is having problems like failing to power on, disconnecting, charging issues, or unresponsive controls, use this guide to replace the motherboard.
The motherboard is the hub of the speaker, responsible for controlling power, audio, connectivity, and lighting. A damaged or faulty motherboard can cause the device to malfunction or stop working entirely.
Before using this guide, try troubleshooting the speaker by performing a full reset or firmware update using the JBL Portable app. Also, confirm that the issue isn’t related to the battery, charger, or other removable components (if these are the issues, look at the JBL Pulse 4 page for those guides).
This guide will walk you through the necessary steps to safely replace the motherboard. Be prepared to handle delicate connectors and use caution when detaching components.
Before beginning, power off the speaker completely and disconnect it from any external power source.
Power off the device before doing any repairs.
Hold the power button for 3+ seconds to power down the device.
Place the speaker on the table with the button board side down.
Remove the three black 5 mm screws using a Phillips #1 screwdriver.
Remove the white casing by pulling it away from the button board.
Tool used on this step:Tweezers$4.99
Using the tweezers, gently unplug the three connections attached to the motherboard.
