JBL Pulse 4 Button Board Replacement
    1. JBL Pulse 4 Button Board Replacement, Casing Replacement: step 1, image 1 of 1
      • Power off the device before doing any repairs.
      • Hold the power button for 3+ seconds to power down the device.
      Ask FixBot
    2. JBL Pulse 4 Button Board Replacement: step 2, image 1 of 3 JBL Pulse 4 Button Board Replacement: step 2, image 2 of 3 JBL Pulse 4 Button Board Replacement: step 2, image 3 of 3
      • Remove each rubber end cap using a plastic pry tool.
      • Go around each end of the speaker slowly popping up a small section of the rubber cap until there is a gap on all sides.
      • Remove the top by hand.
      Ask FixBot
    3. JBL Pulse 4 Button Board Replacement: step 3, image 1 of 3 JBL Pulse 4 Button Board Replacement: step 3, image 2 of 3 JBL Pulse 4 Button Board Replacement: step 3, image 3 of 3
      • Remove the charging port cover using a plastic pry tool.
      • Remove the two 12.7 mm Phillips #1 screws.
      • Remove the charging port housing from the casing.
      Ask FixBot
    4. JBL Pulse 4 Button Board Replacement: step 4, image 1 of 3 JBL Pulse 4 Button Board Replacement: step 4, image 2 of 3 JBL Pulse 4 Button Board Replacement: step 4, image 3 of 3
      • Disconnect the charging port connector by pulling the connector away from the port.
      • Disconnect the battery level indicator light by pulling the wire away from the lights.
      Ask FixBot
    5. JBL Pulse 4 Button Board Replacement: step 5, image 1 of 2 JBL Pulse 4 Button Board Replacement: step 5, image 2 of 2
      • Remove the six 8 mm Phillips #1 screws from the end of the speaker with the grill that says "JBL."
      • Remove the plastic piece where the 6 screws came out of.
      Ask FixBot
    6. JBL Pulse 4 Button Board Replacement: step 6, image 1 of 1
      • Remove the six 9.5 mm screws using a Phillips #1 screwdriver.
      Ask FixBot
    7. JBL Pulse 4 Button Board Replacement: step 7, image 1 of 3 JBL Pulse 4 Button Board Replacement: step 7, image 2 of 3 JBL Pulse 4 Button Board Replacement: step 7, image 3 of 3
      • Flip the speaker to the other end.
      • Use a pry tool to pry between the casing of the speaker and the internals.
      • Go around the entirety of this end of the speaker slowly prying apart the two pieces.
      Ask FixBot
    8. JBL Pulse 4 Button Board Replacement: step 8, image 1 of 1
      • The casing is now fully detached from the internal components.
      • You can now replace the outer casing of the speaker.
      Ask FixBot
    1. JBL Pulse 4 Button Board Replacement, LED Light Display: step 9, image 1 of 2 JBL Pulse 4 Button Board Replacement, LED Light Display: step 9, image 2 of 2
      • Place the speaker on the table with the button board side down.
      • Remove the three black 5 mm screws using a Phillips #1 screwdriver.
      • Remove the white casing by pulling it away from the button board.
      Ask FixBot
    2. JBL Pulse 4 Button Board Replacement: step 10, image 1 of 1
      • Clip off the two zip-ties using the zip tie cutter.
      Ask FixBot
    3. JBL Pulse 4 Button Board Replacement: step 11, image 1 of 1
      • Peel each LED strip off of the speaker using an iFixit opening pick.
      Ask FixBot
    4. JBL Pulse 4 Button Board Replacement: step 12, image 1 of 2 JBL Pulse 4 Button Board Replacement: step 12, image 2 of 2
      • Remove the four black 5 mm screws using a Phillips #1 screwdriver.
      • Remove the white plastic piece that is held in place by the screws.
      Ask FixBot
    5. JBL Pulse 4 Button Board Replacement: step 13, image 1 of 1
      • Remove the red/white cable from the white connection.
      Ask FixBot
    6. JBL Pulse 4 Button Board Replacement: step 14, image 1 of 1
      • Remove the LED light display from the speaker.
      Ask FixBot
    1. JBL Pulse 4 Button Board Replacement, Battery: step 15, image 1 of 3 JBL Pulse 4 Button Board Replacement, Battery: step 15, image 2 of 3 JBL Pulse 4 Button Board Replacement, Battery: step 15, image 3 of 3
      Ask FixBot
    2. JBL Pulse 4 Button Board Replacement: step 16, image 1 of 2 JBL Pulse 4 Button Board Replacement: step 16, image 2 of 2
      • Unplug the cable connecting the battery to the motherboard.
      Ask FixBot
    3. JBL Pulse 4 Button Board Replacement: step 17, image 1 of 2 JBL Pulse 4 Button Board Replacement: step 17, image 2 of 2
      • Feed the wire out of the central housing unit.
      • Pull the battery out of the central housing unit.
      Ask FixBot
    1. JBL Pulse 4 Button Board Replacement, Motherboard: step 18, image 1 of 2 JBL Pulse 4 Button Board Replacement, Motherboard: step 18, image 2 of 2
      Tool used on this step:
      Buy
      • Using the tweezers, gently unplug the three connections attached to the motherboard.
      Ask FixBot
    2. JBL Pulse 4 Button Board Replacement: step 19, image 1 of 3 JBL Pulse 4 Button Board Replacement: step 19, image 2 of 3 JBL Pulse 4 Button Board Replacement: step 19, image 3 of 3
      • Pull the motherboard out of the frame.
      • The only connection the motherboard has to the frame now should be the soldered-on black wire.
      Ask FixBot
    3. JBL Pulse 4 Button Board Replacement: step 20, image 1 of 3 JBL Pulse 4 Button Board Replacement: step 20, image 2 of 3 JBL Pulse 4 Button Board Replacement: step 20, image 3 of 3
      • Desolder the wire from the motherboard.
      • Remove the motherboard from the speaker.
      Ask FixBot
    1. JBL Pulse 4 Button Board Replacement, Button Board: step 21, image 1 of 1
      • Cut the black cable off the motherboard using cutters to remove the button board.
      Ask FixBot
Ethan Zuziak
73 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 40
All Time: 479
