JBL Pulse 3 Speaker Replacement
    1. JBL Pulse 3 Speaker Replacement, Speaker Grill: step 1, image 1 of 1
      • Lay the JBL Pulse 3 on its side as shown in the picture.
      • Use a plastic opening tool to lift the top right corner of the speaker grill. A small amount of force is necessary to remove the grill.
      Ask FixBot
    2. JBL Pulse 3 Speaker Replacement: step 2, image 1 of 1
      • Repeat step 1 for bottom right corner of speaker grill.
      Ask FixBot
    3. JBL Pulse 3 Speaker Replacement: step 3, image 1 of 2 JBL Pulse 3 Speaker Replacement: step 3, image 2 of 2
      • After pulling the right side of the grill off, place thumb underneath grill as shown in the picture.
      • Lift and pull straight out to pull grill off the posts.
      Ask FixBot
      • Repeat steps 1-3 for the left side of the speaker grill on the JBL Pulse 3. The speaker grill should now be completely removed from the JBL Pulse 3.
      Ask FixBot
    1. JBL Pulse 3 Speaker Replacement, Outside Casing: step 5, image 1 of 2 JBL Pulse 3 Speaker Replacement, Outside Casing: step 5, image 2 of 2
      • Use a Phillips #00 screwdriver to remove the six black 6mm screws on the inside of the top of the bottom section.
      Ask FixBot
    2. JBL Pulse 3 Speaker Replacement: step 6, image 1 of 2 JBL Pulse 3 Speaker Replacement: step 6, image 2 of 2
      • Turn the JBL Pulse 3 right-side up and unscrew the top ring of the device. A small amount of force and/or a cotton cloth may be necessary to remove this piece.
      Ask FixBot
    3. JBL Pulse 3 Speaker Replacement: step 7, image 1 of 2 JBL Pulse 3 Speaker Replacement: step 7, image 2 of 2
      • Remove the six 5mm screws on top of the JBL Pulse 3 with a Phillips #0 screwdriver.
      Ask FixBot
    4. JBL Pulse 3 Speaker Replacement: step 8, image 1 of 1
      • Pull off the top disc of the JBL Pulse 3.
      Ask FixBot
    5. JBL Pulse 3 Speaker Replacement: step 9, image 1 of 2 JBL Pulse 3 Speaker Replacement: step 9, image 2 of 2
      • Remove the five 7mm screws on the inside of the JBL Pulse 3 with a Phillips #1 screwdriver.
      Ask FixBot
    6. JBL Pulse 3 Speaker Replacement: step 10, image 1 of 2 JBL Pulse 3 Speaker Replacement: step 10, image 2 of 2
      • Peel off black, taped-on electrical lead from the inside side of the JBL Pulse 3.
      Ask FixBot
    7. JBL Pulse 3 Speaker Replacement: step 11, image 1 of 1
      • Pull the top section of the JBL Pulse 3 up. The outside casing to the JBL Pulse 3 should now be removed.
      Ask FixBot
    1. JBL Pulse 3 Speaker Replacement, LED Light Display: step 12, image 1 of 3 JBL Pulse 3 Speaker Replacement, LED Light Display: step 12, image 2 of 3 JBL Pulse 3 Speaker Replacement, LED Light Display: step 12, image 3 of 3
      • Use a Phillips #2 screwdriver to remove the six 11 mm screws that circle the bottom of the LED light display.
      • Pull the LED light display off of the JBL Pulse 3 base.
      Ask FixBot
    2. JBL Pulse 3 Speaker Replacement: step 13, image 1 of 2 JBL Pulse 3 Speaker Replacement: step 13, image 2 of 2
      Tool used on this step:
      Buy
      • Use tweezers to pull the five connections off of the LED light display.
      Ask FixBot
    1. JBL Pulse 3 Speaker Replacement, Motherboard: step 14, image 1 of 2 JBL Pulse 3 Speaker Replacement, Motherboard: step 14, image 2 of 2
      • Using a Phillips #0 screwdriver, remove the two black 8mm screws on the bottom of the LED light display.
      Ask FixBot
    2. JBL Pulse 3 Speaker Replacement: step 15, image 1 of 3 JBL Pulse 3 Speaker Replacement: step 15, image 2 of 3 JBL Pulse 3 Speaker Replacement: step 15, image 3 of 3
      Buy
      • Pull out the motherboard slightly from the LED light display as shown. Using tweezers, unplug the three connections attached to the motherboard.
      Ask FixBot
    3. JBL Pulse 3 Speaker Replacement: step 16, image 1 of 1
      • Pull the rest of the motherboard out from the LED light display.
      • Using wire cutters, snip the black wire connecting to the base of the JBL Pulse 3 at the base of the motherboard. The motherboard should now be removed from the JBL Pulse 3.
      Ask FixBot
    1. JBL Pulse 3 Speaker Replacement, Speaker: step 17, image 1 of 2 JBL Pulse 3 Speaker Replacement, Speaker: step 17, image 2 of 2
      • Using a Phillips #2 screwdriver, remove the four 10mm screws on the corner of the speaker on the side of the base of the JBL Pulse 3.
      Ask FixBot
    2. JBL Pulse 3 Speaker Replacement: step 18, image 1 of 2 JBL Pulse 3 Speaker Replacement: step 18, image 2 of 2
      • Pull out the speaker and cut the black and red wire with wire cutters. The speaker should now be removed from the JBL Pulse 3.
      Ask FixBot
Note: To finish replacing the speaker, you must solder both wires back on to the new speaker.
2 Guide Comments
My speaker is making weird noises. It sounds like being crack. Do I need to replace the speaker or try to teardown to clean up the dust?
John - Reply Share
Hey Mates. Tell me please, somebody knows , the size of the replacement speaker and it fit from jbl charge 3 or some models? Thanks
Seven Nes - Reply Share
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 40
All Time: 3,816
