JBL Pulse 3 Outside Casing Replacement
    1. JBL Pulse 3 Outside Casing Replacement, Speaker Grill: step 1, image 1 of 1
      • Lay the JBL Pulse 3 on its side as shown in the picture.
      • Use a plastic opening tool to lift the top right corner of the speaker grill. A small amount of force is necessary to remove the grill.
      Ask FixBot
    2. JBL Pulse 3 Outside Casing Replacement: step 2, image 1 of 1
      • Repeat step 1 for bottom right corner of speaker grill.
      Ask FixBot
    3. JBL Pulse 3 Outside Casing Replacement: step 3, image 1 of 2 JBL Pulse 3 Outside Casing Replacement: step 3, image 2 of 2
      • After pulling the right side of the grill off, place thumb underneath grill as shown in the picture.
      • Lift and pull straight out to pull grill off the posts.
      Ask FixBot
      • Repeat steps 1-3 for the left side of the speaker grill on the JBL Pulse 3. The speaker grill should now be completely removed from the JBL Pulse 3.
      Ask FixBot
    1. JBL Pulse 3 Outside Casing Replacement, Outside Casing: step 5, image 1 of 2 JBL Pulse 3 Outside Casing Replacement, Outside Casing: step 5, image 2 of 2
      • Use a Phillips #00 screwdriver to remove the six black 6mm screws on the inside of the top of the bottom section.
      Ask FixBot
    2. JBL Pulse 3 Outside Casing Replacement: step 6, image 1 of 2 JBL Pulse 3 Outside Casing Replacement: step 6, image 2 of 2
      • Turn the JBL Pulse 3 right-side up and unscrew the top ring of the device. A small amount of force and/or a cotton cloth may be necessary to remove this piece.
      Ask FixBot
    3. JBL Pulse 3 Outside Casing Replacement: step 7, image 1 of 2 JBL Pulse 3 Outside Casing Replacement: step 7, image 2 of 2
      • Remove the six 5mm screws on top of the JBL Pulse 3 with a Phillips #0 screwdriver.
      Ask FixBot
    4. JBL Pulse 3 Outside Casing Replacement: step 8, image 1 of 1
      • Pull off the top disc of the JBL Pulse 3.
      Ask FixBot
    5. JBL Pulse 3 Outside Casing Replacement: step 9, image 1 of 2 JBL Pulse 3 Outside Casing Replacement: step 9, image 2 of 2
      • Remove the five 7mm screws on the inside of the JBL Pulse 3 with a Phillips #1 screwdriver.
      Ask FixBot
    6. JBL Pulse 3 Outside Casing Replacement: step 10, image 1 of 2 JBL Pulse 3 Outside Casing Replacement: step 10, image 2 of 2
      • Peel off black, taped-on electrical lead from the inside side of the JBL Pulse 3.
      Ask FixBot
    7. JBL Pulse 3 Outside Casing Replacement: step 11, image 1 of 1
      • Pull the top section of the JBL Pulse 3 up. The outside casing to the JBL Pulse 3 should now be removed.
      Ask FixBot
4 other people completed this guide.
4 Guide Comments
Wherr can I get or buy top ring for Pulse 3?
Mark Christian Mariñas - Reply Share
Please see our device page with the link to the manufacturer’s website. You should be able to find it there.
Kaitlyn Greenfield - Reply Share
I have one of these speakers, and as the delicate outer shell broke it seems nearly impossible to find a replacement…
Any chance to get spare parts in Europe? Thank you.
Raffaele T. - Reply Share
i'm also looking for it, did you find it?
Vladut Alexandru - Reply Share
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 83
All Time: 4,722
