JBL Pulse 3 LED Light Display Replacement
Views: 4.4K
View statistics:
Past 24 Hours:
2
Past 7 Days:
14
Past 30 Days:
73
All Time:
4,387
Comments: 12
8 comments on steps, 4 guide comments.
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 20 minutes
Difficulty: Moderate
Needs More Images
A few more images would make this guide's procedures crystal clear.
Introduction
Go to step 1 ↓
The LED light display is located on the inside of the JBL Pulse 3, under the outside casing. It LED light display is lined with LED light strips along the circular base.
Parts
Tools
    1. JBL Pulse 3 LED Light Display Replacement, Speaker Grill: step 1, image 1 of 1
      • Lay the JBL Pulse 3 on its side as shown in the picture.
      • Use a plastic opening tool to lift the top right corner of the speaker grill. A small amount of force is necessary to remove the grill.
      Ask FixBot
    2. JBL Pulse 3 LED Light Display Replacement: step 2, image 1 of 1
      • Repeat step 1 for bottom right corner of speaker grill.
      Ask FixBot
    3. JBL Pulse 3 LED Light Display Replacement: step 3, image 1 of 2 JBL Pulse 3 LED Light Display Replacement: step 3, image 2 of 2
      • After pulling the right side of the grill off, place thumb underneath grill as shown in the picture.
      • Lift and pull straight out to pull grill off the posts.
      Ask FixBot
      • Repeat steps 1-3 for the left side of the speaker grill on the JBL Pulse 3. The speaker grill should now be completely removed from the JBL Pulse 3.
      Ask FixBot
    1. JBL Pulse 3 LED Light Display Replacement, Outside Casing: step 5, image 1 of 2 JBL Pulse 3 LED Light Display Replacement, Outside Casing: step 5, image 2 of 2
      • Use a Phillips #00 screwdriver to remove the six black 6mm screws on the inside of the top of the bottom section.
      Ask FixBot
    2. JBL Pulse 3 LED Light Display Replacement: step 6, image 1 of 2 JBL Pulse 3 LED Light Display Replacement: step 6, image 2 of 2
      • Turn the JBL Pulse 3 right-side up and unscrew the top ring of the device. A small amount of force and/or a cotton cloth may be necessary to remove this piece.
      Ask FixBot
    3. JBL Pulse 3 LED Light Display Replacement: step 7, image 1 of 2 JBL Pulse 3 LED Light Display Replacement: step 7, image 2 of 2
      • Remove the six 5mm screws on top of the JBL Pulse 3 with a Phillips #0 screwdriver.
      Ask FixBot
    4. JBL Pulse 3 LED Light Display Replacement: step 8, image 1 of 1
      • Pull off the top disc of the JBL Pulse 3.
      Ask FixBot
    5. JBL Pulse 3 LED Light Display Replacement: step 9, image 1 of 2 JBL Pulse 3 LED Light Display Replacement: step 9, image 2 of 2
      • Remove the five 7mm screws on the inside of the JBL Pulse 3 with a Phillips #1 screwdriver.
      Ask FixBot
    6. JBL Pulse 3 LED Light Display Replacement: step 10, image 1 of 2 JBL Pulse 3 LED Light Display Replacement: step 10, image 2 of 2
      • Peel off black, taped-on electrical lead from the inside side of the JBL Pulse 3.
      Ask FixBot
    7. JBL Pulse 3 LED Light Display Replacement: step 11, image 1 of 1
      • Pull the top section of the JBL Pulse 3 up. The outside casing to the JBL Pulse 3 should now be removed.
      Ask FixBot
    1. JBL Pulse 3 LED Light Display Replacement, LED Light Display: step 12, image 1 of 3 JBL Pulse 3 LED Light Display Replacement, LED Light Display: step 12, image 2 of 3 JBL Pulse 3 LED Light Display Replacement, LED Light Display: step 12, image 3 of 3
      • Use a Phillips #2 screwdriver to remove the six 11 mm screws that circle the bottom of the LED light display.
      • Pull the LED light display off of the JBL Pulse 3 base.
      Ask FixBot
    2. JBL Pulse 3 LED Light Display Replacement: step 13, image 1 of 2 JBL Pulse 3 LED Light Display Replacement: step 13, image 2 of 2
      Tool used on this step:
      Buy
      • Use tweezers to pull the five connections off of the LED light display.
      Ask FixBot
3 other people completed this guide.
4 Guide Comments
Hello,I really need some code to show me how to initialize and LED display and how to output data from it.Any help is much appreciated.
Osama Siddiq - Reply Share
Wow jbl
Gyyzhuahyz8yus
Majd Tom - Reply Share
Where to buy the leds?
mj.viana1993 - Reply Share
Hello i need an assitance in a LED screen manufacturing
volkanoo - Reply Share
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 73
All Time: 4,387
