This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
JBL Pulse 3 Battery Replacement
Views: 1.1K
View statistics:
Past 24 Hours:
8
Past 7 Days:
55
Past 30 Days:
213
All Time:
1,083
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 35 minutes
Difficulty: Moderate
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Community-Contributed Guide
Introduction
Go to step 1 ↓
Is your JBL Pulse 3 battery life poor? Won't it turn on?
The battery is likely the culprit; we will show you how to replace it.
Tools
    1. JBL Pulse 3 Battery Replacement, Battery: step 1, image 1 of 1
      • Check your battery model.
      • It is likely that your JBL Pulse 3 is equipped with the same battery as this one.
      • It is recommended to order only original batteries or, at the very least, batteries that meet European standards.
      • This JBL Pulse 3 is equipped with a P5542100-P battery.
      Ask FixBot
    2. JBL Pulse 3 Battery Replacement, Fabric trim removal: step 2, image 1 of 3 JBL Pulse 3 Battery Replacement, Fabric trim removal: step 2, image 2 of 3 JBL Pulse 3 Battery Replacement, Fabric trim removal: step 2, image 3 of 3
      • Use a spudger or an opening pick to remove the trim.
      • You can unclip one side at a time, then gently pull with your fingers to separate the piece.
      Ask FixBot
    3. JBL Pulse 3 Battery Replacement, Upper assembly disassembly: step 3, image 1 of 3 JBL Pulse 3 Battery Replacement, Upper assembly disassembly: step 3, image 2 of 3 JBL Pulse 3 Battery Replacement, Upper assembly disassembly: step 3, image 3 of 3
      • Remove the trim piece, which is simply held in place by a quarter-turn fastener
      • Remove all the screws
      • Now, remove the diaphragm.
      Ask FixBot
    4. JBL Pulse 3 Battery Replacement, Bracket removal: step 4, image 1 of 3 JBL Pulse 3 Battery Replacement, Bracket removal: step 4, image 2 of 3 JBL Pulse 3 Battery Replacement, Bracket removal: step 4, image 3 of 3
      • Remove the screws under the membrane; they hold the LED unit and battery assembly.
      • Take this opportunity to remove the Bluetooth antenna, which is glued on the left in this photo. I advise you not to unplug it from the electronic board. Simply peel it off the wall. Highlighted with the white arrow.
      • Flip the speaker over to the other side and remove the screws holding the LED deflector (the "glass" part that diffuses the colors).
      Ask FixBot
    5. JBL Pulse 3 Battery Replacement: step 5, image 1 of 2 JBL Pulse 3 Battery Replacement: step 5, image 2 of 2
      • You can now gently lift the LED diffuser straight up.
      • There may be some slight resistance. Proceed with caution.
      Ask FixBot
    6. JBL Pulse 3 Battery Replacement, Removal of the bottom screws: step 6, image 1 of 1
      • Remove the screws holding the bottom part of your speaker.
      • It is possible that you cannot extract some screws; this is not a problem. Unscrew them as much as possible.
      Ask FixBot
    7. JBL Pulse 3 Battery Replacement, Lower Case Removal: step 7, image 1 of 3 JBL Pulse 3 Battery Replacement, Lower Case Removal: step 7, image 2 of 3 JBL Pulse 3 Battery Replacement, Lower Case Removal: step 7, image 3 of 3
      • Carefully unclip the lower case. It is simply held in place by snap fits.
      • You can then remove the part by pulling it upward.
      Ask FixBot
    8. JBL Pulse 3 Battery Replacement, Separating the lower section and the LED tube + battery: step 8, image 1 of 3 JBL Pulse 3 Battery Replacement, Separating the lower section and the LED tube + battery: step 8, image 2 of 3 JBL Pulse 3 Battery Replacement, Separating the lower section and the LED tube + battery: step 8, image 3 of 3
      • Remove the screws securing the LED tube, which also contains the battery.
      • Disconnect the cables connecting it to the lower section.
      Ask FixBot
    9. JBL Pulse 3 Battery Replacement, Removal of the remaining support screws: step 9, image 1 of 2 JBL Pulse 3 Battery Replacement, Removal of the remaining support screws: step 9, image 2 of 2
      • Almost there! Remove the screws from the top and bottom of the LED and battery tube.
      • Take this opportunity to remove the cable ties by cutting them with a pair of flush cutters.
      Ask FixBot
    10. JBL Pulse 3 Battery Replacement, LED strip removal: step 10, image 1 of 2 JBL Pulse 3 Battery Replacement, LED strip removal: step 10, image 2 of 2
      • Remove the first three LED strips from your JBL.
      • The first photo shows the first strip. You must remove the three LED strips in a counter-clockwise direction (to the left in the photo).
      • You can use an opening tool if the adhesive is stubborn. Be careful, we are almost there!
      Ask FixBot
    11. JBL Pulse 3 Battery Replacement, LED cable removal: step 11, image 1 of 2 JBL Pulse 3 Battery Replacement, LED cable removal: step 11, image 2 of 2
      • Disconnect the socket that connects the LED assembly to the circuit board.
      • This will make it easier for you to replace the battery.
      Ask FixBot
    12. JBL Pulse 3 Battery Replacement, Opening the battery compartment: step 12, image 1 of 2 JBL Pulse 3 Battery Replacement, Opening the battery compartment: step 12, image 2 of 2
      • There you go! You can open the battery compartment; it's like a shutter. You can open it with your nylon tool.
      Ask FixBot
    13. JBL Pulse 3 Battery Replacement, Disconnecting the battery: step 13, image 1 of 2 JBL Pulse 3 Battery Replacement, Disconnecting the battery: step 13, image 2 of 2
      • All that remains is to remove the battery and replace it.
      • You must unplug the Glued-Down Cables connecting the battery to the board, there are two!
      • WARNING: If your battery is glued in place, DO NOT use a box cutter, knife, or any other sharp object. Doing so could cause a fire or even very serious burns.
      Ask FixBot
To reassemble your device, follow the instructions in reverse order.
Corentin Kezadri
1,837 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 8
Past 7 Days: 55
Past 30 Days: 213
All Time: 1,083
