JBL Pulse 2 Motherboard Replacement
    1. JBL Pulse 2 Motherboard Replacement, Battery: step 1, image 1 of 2 JBL Pulse 2 Motherboard Replacement, Battery: step 1, image 2 of 2
      • Remove the rubber rings from either end of the device.
      • If there is difficulty in lifting the rings from the device, use the metal spudger.
      Ask FixBot
    2. JBL Pulse 2 Motherboard Replacement: step 2, image 1 of 1
      • Remove the four 4.8mm Phillips #1 screws from each end of the device with the Phillips head screwdriver.
      • Lift the end pieces off of the device.
      Ask FixBot
    3. JBL Pulse 2 Motherboard Replacement: step 3, image 1 of 1
      • Remove the four 9.5mm Phillips #1 screws from each end of the device.
      Ask FixBot
    4. JBL Pulse 2 Motherboard Replacement: step 4, image 1 of 2 JBL Pulse 2 Motherboard Replacement: step 4, image 2 of 2
      • Peel one end off and slowly draw it across the length of the device until you get to the other side.
      Ask FixBot
    5. JBL Pulse 2 Motherboard Replacement: step 5, image 1 of 3 JBL Pulse 2 Motherboard Replacement: step 5, image 2 of 3 JBL Pulse 2 Motherboard Replacement: step 5, image 3 of 3
      • Remove the four 7.9mm Phillips #1 screws along the black centerpiece of the device between the camera and the auxiliary port.
      • Lift up the casing and circuit board but do not try and remove the ribbon wires.
      Ask FixBot
    6. JBL Pulse 2 Motherboard Replacement: step 6, image 1 of 1
      • Remove the cover from the end that the ribbon wires are attached to. It should peel off easily.
      Ask FixBot
    7. JBL Pulse 2 Motherboard Replacement: step 7, image 1 of 2 JBL Pulse 2 Motherboard Replacement: step 7, image 2 of 2
      • Unlatch the mechanism holding the ribbon wires in place, then disconnect them from the motherboard.
      • To access the wires, remove some of the black glue holding them in place with the spudger.
      Ask FixBot
    8. JBL Pulse 2 Motherboard Replacement: step 8, image 1 of 2 JBL Pulse 2 Motherboard Replacement: step 8, image 2 of 2
      • Slowly pull the ribbon wires out from the outside.
      • If there is too much resistance, remove more of the black glue.
      Ask FixBot
    9. JBL Pulse 2 Motherboard Replacement: step 9, image 1 of 2 JBL Pulse 2 Motherboard Replacement: step 9, image 2 of 2
      • Remove the four 7.9mm Phillips #1 screws around the edges of the center piece.
      • Slide the outer casing off away from the auxiliary and micro USB port.
      Ask FixBot
    10. JBL Pulse 2 Motherboard Replacement: step 10, image 1 of 1
      • Remove the other end of the device to access the wiring underneath it.
      Ask FixBot
    11. JBL Pulse 2 Motherboard Replacement: step 11, image 1 of 1
      Tool used on this step:
      $3.99
      Buy
      • Use the angled tweezers to disconnect the battery from the motherboard. It will take some work to remove this piece.
      Ask FixBot
    12. JBL Pulse 2 Motherboard Replacement: step 12, image 1 of 1
      • Remove the four 7.9mm Phillips #1 screws from the black centerpiece of the device.
      Ask FixBot
    13. JBL Pulse 2 Motherboard Replacement: step 13, image 1 of 2 JBL Pulse 2 Motherboard Replacement: step 13, image 2 of 2
      • Use the spudger to reach under the sides of the black centerpiece to access the six latches, three of which are on each side.
      Ask FixBot
    14. JBL Pulse 2 Motherboard Replacement: step 14, image 1 of 2 JBL Pulse 2 Motherboard Replacement: step 14, image 2 of 2
      • Lift the black centerpiece off with the metal spudger to reveal the battery underneath.
      Ask FixBot
    15. JBL Pulse 2 Motherboard Replacement: step 15, image 1 of 1
      • Use a hot air gun to soften the hot glue in order to fully remove the battery.
      Ask FixBot
    1. JBL Pulse 2 Motherboard Replacement, Motherboard: step 16, image 1 of 3 JBL Pulse 2 Motherboard Replacement, Motherboard: step 16, image 2 of 3 JBL Pulse 2 Motherboard Replacement, Motherboard: step 16, image 3 of 3
      • Manually remove the LED strips from the outside of the white plastic casing.
      Ask FixBot
    2. JBL Pulse 2 Motherboard Replacement: step 17, image 1 of 3 JBL Pulse 2 Motherboard Replacement: step 17, image 2 of 3 JBL Pulse 2 Motherboard Replacement: step 17, image 3 of 3
      • Use the Phillips #1 screwdriver to remove the ten 9.5mm screws that hold the cage in place.
      • Lift the cage off.
      Ask FixBot
    3. JBL Pulse 2 Motherboard Replacement: step 18, image 1 of 2 JBL Pulse 2 Motherboard Replacement: step 18, image 2 of 2
      • Use the Phillips #1 screwdriver to remove the eight 6.4mm screws that hold the speakers in place.
      • Partially remove the speakers so you can see where they connect to the motherboard.
      Ask FixBot
    4. JBL Pulse 2 Motherboard Replacement: step 19, image 1 of 2 JBL Pulse 2 Motherboard Replacement: step 19, image 2 of 2
      Buy
      • Use the straight tweezers to disconnect the speakers from the motherboard.
      • Fully remove the speakers once they are disconnected from the motherboard.
      Ask FixBot
    5. JBL Pulse 2 Motherboard Replacement: step 20, image 1 of 1
      • Disconnect the remaining wires from the motherboard with the straight tweezers.
      • Be cautious when performing this step. The mic wire is fragile and liable to break.
      Ask FixBot
    6. JBL Pulse 2 Motherboard Replacement: step 21, image 1 of 1
      • Use a hot air gun to soften the glue from the corners of the motherboard.
      • Slide the motherboard out of the casing.
      • The hot glue covers portions of the motherboard so be careful when softening and removing it.
      Ask FixBot
4 other people completed this guide.
1 Guide Comment
Well taught tnx
Deepak Soni - Reply Share
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 41
All Time: 3,056
