JBL Pulse 2 Button Circuit Board Replacement
    1. JBL Pulse 2 Button Circuit Board Replacement, Button Circuit Board: step 1, image 1 of 2 JBL Pulse 2 Button Circuit Board Replacement, Button Circuit Board: step 1, image 2 of 2
      • Remove the rubber rings from either end of the device.
      • If there is difficulty in lifting the rings from the device, use the metal spudger.
      Ask FixBot
    2. JBL Pulse 2 Button Circuit Board Replacement: step 2, image 1 of 1
      • Remove the four 4.8mm Phillips #1 screws from each end of the device with the Phillips head screwdriver.
      • Lift the end pieces off of the device.
      Ask FixBot
    3. JBL Pulse 2 Button Circuit Board Replacement: step 3, image 1 of 1
      • Remove the four 9.5mm Phillips #1 screws from each end of the device.
      Ask FixBot
    4. JBL Pulse 2 Button Circuit Board Replacement: step 4, image 1 of 2 JBL Pulse 2 Button Circuit Board Replacement: step 4, image 2 of 2
      • Peel one end off and slowly draw it across the length of the device until you get to the other side.
      Ask FixBot
    5. JBL Pulse 2 Button Circuit Board Replacement: step 5, image 1 of 3 JBL Pulse 2 Button Circuit Board Replacement: step 5, image 2 of 3 JBL Pulse 2 Button Circuit Board Replacement: step 5, image 3 of 3
      • Remove the four 7.9mm Phillips #1 screws along the black centerpiece of the device between the camera and the auxiliary port.
      • Lift up the casing and circuit board but do not try and remove the ribbon wires.
      Ask FixBot
    6. JBL Pulse 2 Button Circuit Board Replacement: step 6, image 1 of 1
      • Remove the cover from the end that the ribbon wires are attached to. It should peel off easily.
      Ask FixBot
    7. JBL Pulse 2 Button Circuit Board Replacement: step 7, image 1 of 2 JBL Pulse 2 Button Circuit Board Replacement: step 7, image 2 of 2
      • Unlatch the mechanism holding the ribbon wires in place then disconnect them from the motherboard.
      • To access the wires, remove some of the black glue holding them in place with the spudger.
      Ask FixBot
    8. JBL Pulse 2 Button Circuit Board Replacement: step 8, image 1 of 2 JBL Pulse 2 Button Circuit Board Replacement: step 8, image 2 of 2
      • Slowly pull the ribbon wires out from the outside.
      • If there is too much resistance, remove more of the black glue.
      Ask FixBot
3 other people completed this guide.
4 Guide Comments
where can I buy that part
Wilco Peters - Reply Share
I love you guys
Davi Dodo - Reply Share
I need to buy parts
hernzum - Reply Share
How can I find the cable connecting main board and button circuit
MARK SAMUDENI - Reply Share
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 35
All Time: 1,708
