Introduction
The JBL Live 660NC headphones (also known as JBL Live 660 NC or JBL Live 660NCBT) may require a motherboard replacement if you attempted to repair it's battery, drivers, or charging port. This guide will teach you on how to properly replace the motherboard in case of a short in the motherboard, lifecycle ending, or improper care. Always be careful when performing any step in this guide, as the motherboard is a fragile part of any electronic device.
Check out this guide to safely desolder components before proceeding.
Use a Jimmy or spudger to pry the bezel around the JBL plate.
Gently slide the tool around the edges to loosen the clips.
Lift the bezel off.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
