This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
JBL Link 20 Battery Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
22
Past 30 Days:
108
All Time:
361
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 minutes
Difficulty: Moderate
Community-Contributed Guide
Introduction
Go to step 1 ↓
Since the battery would no longer charge after a few years, I decided to replace it myself. Here is my first step-by-step guide.
Parts
Tools
    1. JBL Link 20 Battery Replacement, Disassemble the top and bottom: step 1, image 1 of 2 JBL Link 20 Battery Replacement, Disassemble the top and bottom: step 1, image 2 of 2
      • Use your Jimmie or spudger to get between the rubber and the plastic, then go around the perimeter and slowly pry the rubber up.
      • Remove the 5 Phillips screws using your driver bit.
      Ask FixBot
    2. JBL Link 20 Battery Replacement: step 2, image 1 of 2 JBL Link 20 Battery Replacement: step 2, image 2 of 2
      • Use your Angled Tweezers to gently pry up the gray clip to release the cable.
      • Remove the screws in the corners, but leave the plastic in place for now. It is still secured by 2 difficult screws elsewhere.
      Ask FixBot
    3. JBL Link 20 Battery Replacement, Bottom cover: step 3, image 1 of 2 JBL Link 20 Battery Replacement, Bottom cover: step 3, image 2 of 2
      • Follow the same procedure as step 1: detach using a Jimmy and remove the Phillips screws.
      • Disconnect the cables using your angled tweezers (flip up the grey flap).
      Ask FixBot
    4. JBL Link 20 Battery Replacement, Removing the casing: step 4, image 1 of 2 JBL Link 20 Battery Replacement, Removing the casing: step 4, image 2 of 2
      • Use your Jimmy and spudger to pry along the seam of the casing to lift it.
      • There are clips at the top and bottom that are snapped over a tab. It may be helpful to carefully insert a tool behind these areas if the casing remains stuck at the top or bottom while you are prying it loose.
      • Once loose, slide the casing off the internal assembly.
      Ask FixBot
    5. JBL Link 20 Battery Replacement, Last step?: step 5, image 1 of 3 JBL Link 20 Battery Replacement, Last step?: step 5, image 2 of 3 JBL Link 20 Battery Replacement, Last step?: step 5, image 3 of 3
      • Remove the metal plate and try to unscrew the 2 hidden screws.
      • You can then detach the plate from a few steps earlier at the top. Mind the 2 cables with the grey clips again.
      • You can now disconnect the battery (white connector) and replace it.
      Ask FixBot
Scooter017
148 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 22
Past 30 Days: 108
All Time: 361
