JBL L26 Speaker Replacement
Views: 2.1K
View statistics:
Past 24 Hours:
6
Past 7 Days:
24
Past 30 Days:
81
All Time:
2,134
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 25 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
This guide will show you the step by step process of replacing a speaker for a JBL L26 speaker system. The process won’t be too difficult, but be careful when removing parts such as the terminal connector because they are fragile. There are similar JBL speakers like the model L40 which follow the same steps.
    1. JBL L26 Speaker Replacement, Speaker: step 1, image 1 of 1
      • Remove the four 6.4 mm Phillips #2 screws from the front of the speaker.
      Ask FixBot
    2. JBL L26 Speaker Replacement: step 2, image 1 of 1
      • Pull the speaker out of the frame and lay it onto the side.
      Ask FixBot
    3. JBL L26 Speaker Replacement: step 3, image 1 of 1
      • Unlatch the green wire by pulling on the terminal connector and not the wire.
      Ask FixBot
    4. JBL L26 Speaker Replacement: step 4, image 1 of 2 JBL L26 Speaker Replacement: step 4, image 2 of 2
      • Use a small prying tool to pry the terminal connector off of the tap.
      • After you unlatched both edges, pull the black wire out.
      Ask FixBot
    5. JBL L26 Speaker Replacement: step 5, image 1 of 1
      • Get your replacement speaker and connect the green wire by pushing the terminal connector onto the tap.
      Ask FixBot
    6. JBL L26 Speaker Replacement: step 6, image 1 of 2 JBL L26 Speaker Replacement: step 6, image 2 of 2
      • Connect the black wire by attaching the terminal connector onto the tap.
      • Use a clamping tool to clip the edges toward the tap.
      • Be careful not to clamp too hard so you don't damage the tap.
      Ask FixBot
    7. JBL L26 Speaker Replacement: step 7, image 1 of 1
      • Place the new speaker onto the frame and screw the four 6.4 mm Phillips #2 screws back in.
      Ask FixBot
Nathnael Dubale
269 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 24
Past 30 Days: 81
All Time: 2,134
