Tools
Introduction
Go to step 1 ↓This guide will walk you through safely removing and replacing the LED board in your JBL Grip speaker. Replacing the LED board may be necessary if the speaker’s lights no longer turn on, appear dim, flicker during use, stay stuck on a single color, or fail to respond properly while charging or in use.
The LED board is located inside the speaker and is connected to other internal components through small wires and connectors. Accessing it requires removing the outer casing and charging port panel, which means you will need to handle small screws, delicate clips, and internal cables carefully throughout the repair.
Before starting, power the speaker off completely and disconnect it from any charging cable or power source.
Remove the eight 6mm screws securing the panel with a Phillips #2 screwdriver.
Remove the four 3mm screws securing the board to panel with a Phillips #2 screwdriver.
