Introduction
This guide will show you how to remove the charging port panel on the JBL Grip speaker. This step is required to access and disconnect the charging port assembly for repair or replacement.
The panel is secured with multiple screws and connected by delicate ribbon cables. Care must be taken when removing screws and disconnecting cables to avoid damaging connectors or internal components.
Remove the eight 6mm screws securing the panel with a Phillips #2 screwdriver.
