Tools
Introduction
Go to step 1 ↓This guide will show you how to safely remove the outer case (membrane) of the JBL Grip speaker. Removing the membrane is a necessary first step to access the internal components of the device, including the charging port and internal circuitry.
The outer case is secured by clips and adhesive, so it must be handled carefully to avoid tearing or deforming the material. Use the recommended tools and apply gentle, even pressure when separating the membrane.
