Up to 20% off select tools
JBL Grip Battery Replacement
View statistics:
Past 24 Hours:
8
Past 7 Days:
44
Past 30 Days:
173
All Time:
779
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 - 20 minutes
Difficulty: Moderate
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Tools
Introduction
Go to step 1 ↓
This guide will show you how to safely remove and replace the battery in your JBL Grip speaker. You may need to perform this repair if your speaker no longer holds a charge, powers off unexpectedly, or fails to turn on.
The battery is located inside the device and requires removing the outer case and internal components to access it. During this process, you will disconnect delicate cables and remove several screws, so handle all components carefully to avoid damage.
    1. JBL Grip Battery Replacement, Case: step 1, image 1 of 2 JBL Grip Battery Replacement, Case: step 1, image 2 of 2
      • Slide the Jimmy along the seam to separate the case.
      • Caution: Do not bend or puncture membrane.
      Ask FixBot
    2. JBL Grip Battery Replacement: step 2, image 1 of 2 JBL Grip Battery Replacement: step 2, image 2 of 2
      • Unlatch the membrane from the rest of body.
      Ask FixBot
    1. JBL Grip Battery Replacement, Charging Port Panel: step 3, image 1 of 2 JBL Grip Battery Replacement, Charging Port Panel: step 3, image 2 of 2
      • Remove the eight 6mm screws securing the panel with a Phillips #2 screwdriver.
      Ask FixBot
    2. JBL Grip Battery Replacement: step 4, image 1 of 3 JBL Grip Battery Replacement: step 4, image 2 of 3 JBL Grip Battery Replacement: step 4, image 3 of 3
      • Flip up the black latches securing the two blue cables connected to the panel.
      • Caution: Do not pull the cables by force. Ensure the latches are fully lifted.
      Ask FixBot
    1. JBL Grip Battery Replacement, Battery: step 5, image 1 of 2 JBL Grip Battery Replacement, Battery: step 5, image 2 of 2
      • Carefully pull the detached end of the battery from the chassis.
      • Be sure not to pull too hard; the cables are fragile.
      Ask FixBot
    2. JBL Grip Battery Replacement: step 6, image 1 of 2 JBL Grip Battery Replacement: step 6, image 2 of 2
      • Unplug the wires from their socket.
      • Be gentle; these parts are fragile.
      • Once the wire is unplugged, safely remove it.
      Ask FixBot
Author
with
Isaac Loma
798 Reputation
7 Guides authored
0 Guide Comments
Past 24 Hours: 8
Past 7 Days: 44
Past 30 Days: 173
All Time: 779
