JBL Go Repair Motherboard Replacement
    1. JBL Go Repair Motherboard Replacement, Front Cover: step 1, image 1 of 1
      • Use an opening tool to scrape around the outside of the front cover to remove the glue attaching it to the surrounding rubber layer.
      Ask FixBot
    2. JBL Go Repair Motherboard Replacement: step 2, image 1 of 1
      • Once you have scraped off all of the glue, use the opening tool to pry up the front cover.
      Ask FixBot
    3. JBL Go Repair Motherboard Replacement: step 3, image 1 of 1
      • Carefully remove the loose plastic cover from the speaker.
      Ask FixBot
    1. JBL Go Repair Motherboard Replacement, Motherboard: step 4, image 1 of 1
      • Once the front cover is removed, use a T6 screwdriver to remove the four 9 mm screws on the black cover.
      Ask FixBot
    2. JBL Go Repair Motherboard Replacement: step 5, image 1 of 1
      • After removing the screws, use the plastic opening tool to carefully pry around the edges of the black cover to loosen and lift the cover off of the device.
      Ask FixBot
    3. JBL Go Repair Motherboard Replacement: step 6, image 1 of 1
      • Carefully unplug the woofer wires from the motherboard.
      Ask FixBot
    4. JBL Go Repair Motherboard Replacement: step 7, image 1 of 1
      • Use the T6 screwdriver to remove the 9 mm screw that secures the motherboard in place.
      Ask FixBot
    5. JBL Go Repair Motherboard Replacement: step 8, image 1 of 1
      • Lift the motherboard using the plastic opening tool and stick it through the hole in the middle of the board.
      Ask FixBot
    6. JBL Go Repair Motherboard Replacement: step 9, image 1 of 1
      • Carefully lift the motherboard, sliding the charging port side out of the frame of the speaker as you go.
      Ask FixBot
9 other people completed this guide.
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 43
Past 30 Days: 152
All Time: 6,658
