Up to 20% off select tools
JBL Go Repair Front Cover Replacement
Views: 4.2K
View statistics:
Past 24 Hours:
4
Past 7 Days:
29
Past 30 Days:
171
All Time:
4,205
Comments: 1
1 comment on steps.
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 2 - 5 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Use this guide to replace a damaged front cover of your JBL Go.
The outer front cover protects the rest of the parts of your speaker. If it becomes damaged, then the other parts could become damaged, as well. This could also affect the audio quality of your speaker.
Steps 1 and 2 require the use of an opening tool to scrape away the glue that holds the front cover in place. This glue is strong, so be careful as you scrape because you could cut yourself with the opening tool.
    1. JBL Go Repair Front Cover Replacement, Front Cover: step 1, image 1 of 1
      • Use an opening tool to scrape around the outside of the front cover to remove the glue attaching it to the surrounding rubber layer.
      Ask FixBot
    2. JBL Go Repair Front Cover Replacement: step 2, image 1 of 1
      • Once you have scraped off all of the glue, use the opening tool to pry up the front cover.
      Ask FixBot
    3. JBL Go Repair Front Cover Replacement: step 3, image 1 of 1
      • Carefully remove the loose plastic cover from the speaker.
      Ask FixBot
4 other people completed this guide.
Author
with
Sydney Jason
869 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 29
Past 30 Days: 171
All Time: 4,205
