JBL Go Repair Foam Surround Replacement
    1. JBL Go Repair Foam Surround Replacement, Front Cover: step 1, image 1 of 1
      • Use an opening tool to scrape around the outside of the front cover to remove the glue attaching it to the surrounding rubber layer.
      Ask FixBot
    2. JBL Go Repair Foam Surround Replacement: step 2, image 1 of 1
      • Once you have scraped off all of the glue, use the opening tool to pry up the front cover.
      Ask FixBot
    3. JBL Go Repair Foam Surround Replacement: step 3, image 1 of 1
      • Carefully remove the loose plastic cover from the speaker.
      Ask FixBot
    1. JBL Go Repair Foam Surround Replacement, Woofer: step 4, image 1 of 2 JBL Go Repair Foam Surround Replacement, Woofer: step 4, image 2 of 2
      • Once the front cover is removed, use a T6 screwdriver head to remove the four 9 mm screws on the black cover.
      Ask FixBot
    2. JBL Go Repair Foam Surround Replacement: step 5, image 1 of 1
      • After removing the screws, use the plastic opening tool to carefully pry around the edges of the black cover to loosen and lift the cover off of the device.
      Ask FixBot
    3. JBL Go Repair Foam Surround Replacement: step 6, image 1 of 1
      • Carefully unplug the woofer wires from the motherboard
      Ask FixBot
    4. JBL Go Repair Foam Surround Replacement: step 7, image 1 of 1
      • Once the black cover is fully detached from the speaker, unscrew the woofer from the back of the black cover using a T6 screwdriver head.
      Ask FixBot
    1. JBL Go Repair Foam Surround Replacement, Foam Surround: step 8, image 1 of 1
      Tool used on this step:
      Buy
      • Once the woofer is removed, use sharp tweezers to carefully remove the foam surround from the woofer.
      Ask FixBot
4 other people completed this guide.
2 Guide Comments
what is the size of the foam surround?
John Darrel Baytan - Reply Share
size of foam surround: 1.9"
776831 - Reply Share
Past 24 Hours: 5
Past 7 Days: 29
Past 30 Days: 133
All Time: 4,003
